      Oct 2009
      Garland, Tx
      Looking for Chevelle rear axle 4-link Brackets
      I've got the perfect width 9" Ford rear end for my El Camino ('66). I'm looking for the upper and lower brackets to weld on. I know I've seen them before but can't remember where.
      I haven't been able to find if Currie has them or not (looking on their website) but they'd be the same brackets welded to their housings.
      Anybody have a source? Thanks!
      May 2002
      Northern California
      Try ridetech or Chris Alstons Chassisworks.
      Or you can always make a jig off of your old rear end, make templates out of heavy construction paper, take them to a water jet shop and have them cut out of 3/16" cold rolled steel.
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Loganville, GA
      Here is another option, it's meant for the 78-88 G-body but should be adaptable to your car.
      http://www.speedwaymotors.com/Deluxe...Kit,23683.html
      Here is what it looks like on a 9" axle
      http://www.speedwaymotors.com/9-Inch...ets,25595.html
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      We (Chris Alston's Chassisworks) just finished our A-body rear coil-over conversion kit and g-Bar/g-Link suspension. Each can be ordered with bolt-on or weld-on brackets. The basic kit is part number 5824-A10.
      We have the upper arm housing mounts we use for our FAB9 center section, but you may have to do some trimming or extending to get them to fit a factory 9" housing.
      Bolt-in upper and lower mounts:
      Weld-in upper crossmember and lower mounts:
      Weld-in lower bracket detail:
      Adjustable billet shock mount:
      Additional information will be posted to our website later this week.
      In the meantime, reply or call for more info.
      Lino Chestang
      Oct 2006
      Colorado
      I'm glad Chris Alston is finally offering the brackets and hardware apart from the triangulated 4 link/bar packages. I've got a Mopar and have called several times before trying to buy just the brackets and shock mounts without any luck. I've always been told I'd have to buy the Chevy or Ford 4-bar, etc. and modify it. This is perfect. Nice!
      Thanks, Wes
      Oct 2006
      Colorado
      Psydwaze-PM sent.
