Results 1 to 13 of 13
Thread: q-jet help
- Jan 2006
- 127
q-jet help
I have a quadrajet in a 69 corvette that has sat idle for maybe a year. I just bought it, but ostensibly, it ran fine before storage. It now starts hard, idles rough, and has a small backfire when the throttle is blipped. It won't rev over approximately 2500 rpm and runs roughly at all rpm.
I checked the ignition and valve timing-both appear to be correct. Compression is consistently ~125 psi, no vacuum reading yet (lent gauge to a friend).
The thing acts like plug wires are switched (those check okay). It also has classic lean backfire symptoms. However, the plugs get fouled (black and wet-like it's rich).
I've been out of the carburetor game for a long time, so, is this just a case of a carb that is gummed up from sitting too long?
