Results 21 to 40 of 81
Thread: Hollow or Solid Sway Bar
06-17-2010 #21
This may well be the perfect summary. It's all about individual needs and the combination you're putting together. Wrong answer to concentrate on the sway bar and excluding the remainder of the suspension/chassis.
Norm - agreed. I should clarify, I meant that in terms of "Strength" or the "ability to resist deflection/flex" overkill provides no value. In terms of "performance", too much may well be a bad thing.
06-17-2010 #22I would bet my RARE billets are heavier than my stamped steel sure not dramatically lighter. Point was as one of the other guys said 8 lbs difference of non sprung weight is a little more than a gallon of gas in the tank. Probably more than that of sound deadener or jute in the carpet in most cars.
Interested now on the braided line, I might have to weigh on an accurate scale a steel fuel line vs a equal length of braid with hose ends on it. That said I like braided and use it over steel lines.
06-17-2010 #23I know my March non-air system is significantly lighter than steel pulleys and brackets - by a LONG shot. I've installed the RARE pulleys, and can't say for sure about them. They are great quality pieces, but I think there are pretty thick and heavy. Beyond that, I think we're arguing fractions, but frankly the entire gas in the tank argument further shows the value of decreasing the weight of front suspension components for many of us driving 60s/70s PT cars. Without starting a physics lesson, let's just say that the further forward in the car the weight, the more its effect on balance, OK? Because so many of our cars from the factory had heavy front ends and light rear ends, we like to move that balance point back, right? At the same time, as we drive, we LOSE weight (in fuel) in the fuel cell/tank. Meaning, that over every mile you're moving the "balance point" forward in the car due to less fuel (or ballast) in the back. So, at least from my perspective, I'm happy for every pound I can move back behind the drivers seat. MOVING weight (or percentage of mass) is more important to me than LOSING weight.
06-18-2010 #24I agree moving weight off the front end helps balance most cars better esp since most of our early cars are so nose heavy. I think some of it though is more a theoretical thing though. Even my current pump gas TA car at the drags ran identical times/mph with the 22lb sway bar added back on the front and hooked up. Two things that in theory should slow it down with weight and weight transfer.
Now light weight skinny front tires went faster than just the weight difference I assume form the decreased rolling resistance and being sprung weight.
I would still bet you if you had a close size solid sway bar to a hollow and did an autocross there would be more variables in your lap time than what the bar did weight wise or handling.
06-18-2010 #25First, no relationship whatsoever between 1/4 drag performance and road racing/autox performance. We're not talking about how much drag slicks improve drag performance so they should be applied to autox, right?
Second, the skinny tires and wheels are UNSPRUNG and not sprung weight. But your point is correct in that weight in the tire/wheel will have a greater effect due to the physics of rotational energy.
Most important, like I said - if you're replacing the bar anyway, no reason to NOT get a tubular bar as opposed to a solid bar. If you don't need to replace the bar, then it's probably not going to make a measurable difference.
Keep in mind, though - the really good builds are not the result of one or two really light or better components. They are the result of the COMBINATION of MANY good decisions and improvements. A pound here, an ounce there, right?
06-18-2010 #26That's true. But we're just talking about one item here though. If you had that thought for each part you purchased when building a car, you'll be several hundred pounds heavier than what you could be. I understand there is a cost to benefit ratio to consider as well...
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
06-21-2010 #27
- Nov 2004
- Gilbert, Arizona
- 50
Well........I got my Hotchkis Sway bar from Summit on Friday and got it installed on Saturday. I didn't drive it much on Saturday, but I drove it into work today and it feels great. I took a hard corner this morning and the car felt very level and had no push in the corner. I didn't push it to the limit since it was the first hard corner that I have taken. My onboard "G-meter" in my kenwood deck said .92 Gs. The previous reading had been .85 Gs. So far I love it. There is one thing though, the clearance between the sway bar and the idler arm are incredibly close. There is a note about this on the installation instructions. I have the Moog Problem solver arm which is bigger then what Hotchkis says will fit. So far it seems fine. No rubbing, but I will keep an eye on it
Z-28 has a built 383SBC. The heads are AFR 195 CNC ported with a 274 Solid Extreme Energy Cam. 1.6 rockers an Edelbrock RPM Air Gap intake and a 650 Holley carb. Turbo400 with a 10" ATI convertor 3200 Stall. 3.42 posi. Hotchkis springs/swaybar/UCA and Bilstein shocks.
06-22-2010 #28"First, no relationship whatsoever between 1/4 drag performance and road racing/autox performance. We're not talking about how much drag slicks improve drag performance so they should be applied to autox, right?"
I'll diasagree-some of the concept is still the same -lighter wheels have less inertia effect to accelerate and stop be they drag or autocross. In drag racing it is much easier to quantitate exact weight vs performance based strictly on weight(done that class racing adding and subtracting weight . I would also bet going wider tires autocrossing/road racing than you need for traction would slow you down also. And I've autocrossed with light weight wheels and autocross compound DOT tires and heavier wheels(cheaper) and road race slicks. No comparison the slicks will kick the DOTs rear(CP vs ESP in SCCA). I've been a few laps around tracks as well as straight line. John Berget has lots of roadrace slicks in all sizes.
Of course in autocross or road race we generally are not looking for small tread to reduce rolling resistance as in drag racing, but going too big even if they fit(usually the limiting factor) will slow you down.
Matt I agree with you in part that every little bit adds up. I would bet though most of the guys here have more street touring cars with thing like stereos/amps, electric windows etc etc that eat up any little savings thing like 8lbs in a sway bar would save. Now a purpose built race car-different thing. Heck while painting my TA years ago while autocrossing it I thought man I'll take the torch to those front bumper supports and cut big holes every where. Spent all day and save a whole 12 lbs on the front and 9 on the rear!
And then I always joke to my bigger friends to put my skinny butt in their car if they need an all time faster time
06-22-2010 #29Sorry, but I couldn't disagree more with the previous post. There are SO few similarities between autox and drag performance that you may as well say there are none. Think about CoD, differences in camber, caster, effects on shock performance (ie, in drag racing, a softer front end goes faster - try that in autox once, OK?), the different effects of weight location and center of gravity, and the list goes on.
About the only thing I see is both would benefit from less weight in general, more power, and better traction. But HOW you get each of them is totally and completely different. Find me one single car setup properly for 1/4 mile slips that can go around a corner..... Just one. I mean one optimized for drag. Think of it another way. Take a 'Busa bike setup for drags and try to ride it fast on a road course. Make sure somebody has a camera first, though
Bottom line remains the same. Every little bit helps. It probably won't make a measurable difference in terms of weight by itself. If your sway bar is already performing well, probably not cost effective for most people to swap it. If you need a better sway bar anyway, no reason NOT to get tubular. It IS a better quality component. The difference between nice cars and REALLY nice cars is the combined attention to detail on the combination.
06-22-2010 #30
