    Results 1 to 9 of 9
      Sep 2009
      calgary alberta canada
      harmaonic vibration
      Just rebuilt my 69 chevelle power train from the tranny back new fordgline 18 inch wheels new bearings balenced the drive shaft u joints disk brakes all new and now at 70 mph Ive got this harmonic vibration that I cant figure out any one with this same problem have any solutions.
      Jan 2007
      CT
      would help to know what trans / rear gear / rear suspension / driveshaft shaft diam. / Trans mount / body mounts / who's driveshaft / RPM and Gear vibration happens at.
      All these variables can create unwanted harmonics.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Oct 2009
      Sleepy Hollow,IL
      I had a strange vibration but at a certain rpm. New trans, engine and driveshaft. It was the fan clutch.
      Everything Under the Sun is Intune
      Chris
      http://www.popularhotrodding.com/fea..._am/index.html
      Sep 2009
      the tranny is a turbo 400 with a 3500 stall springs are made by quickensuspension with internal air bags rear end is a 12 bolt posi with 355 gears and mozer axcle bearings the driveshaft is stock and was balanced transmount is new stock body mounts are new stock as for rpm mostley at highway speeds above 4000 rpm under 60 mph its smooth. and the fan clutch is new as well.
      Henderson,NV
      Working angles, more specifically driveline angles. You've made some engine and suspension modifications. You need to dial it back in...
      Todd
      Jonesboro, Arkansas
      Quote Originally Posted by Taman View Post
      I've had this happen as well!!! Although several years ago.
      Carl Wilson
      Jan 2007
      CT
      there is some good info here for checking your angles.
      http://www.drivetrain.com/parts_cata..._problems.html
      ________________
      Nick S.
      USA
      Check your powertrain ( driveline) , driveshaft , and pinion angles..
      Jeff Tate
      U.S.A.
      Sep 2009
      Thanks for the info checked the u joints first they looked and felt great but just to be on the safe side I changed both the front and back to a high strenght units and it fixed the problem until I get to the 90 to 100 mph speeds and miss harmonic came back now I going to play with the pinion angles to see if this will get rid of it at warp speed the drive train .com web site is a good site for refrence I keep you posted if this works
