      Apr 2010
      69 Firebird - Brake upgrade recommendations.
      To get Project: Death Machine kicked off (69 firebird), progress thread located here
      https://www.pro-touring.com/forum/sh...ad.php?t=68672
      I need to figure out what I want to do with the brakes, the master cylinder in particular. I've read on these forums about the hydroboost system that utilizes hydraulic energy from the power steering pump to power the brakes. The car currently has front discs on the front stock spindles and discs in the back (Ford 9" mini-tubbed rear end). I plan on keeping these brakes on for now and possibly updating the fronts to larger discs at a later time. (Side note: I plan on running a Boze Pro-touring 18"/19" wheel setup).
      Can I get some recommendations on what master cylinder I should use and what kind of price I'd be looking at? I already have the stock lines that I could utilize to cut down on some costs, but I'll be needing some extra line along the way. I'm guessing I need the following parts at this point:
      Master Cylinder (Wilwood or Hydroboost)
      Distribution block
      Proportioning Valve
      Misc. brake line
      Misc. fittings
      Arm to connect the brake lever
      Firewall mounting plate?
      The car will eventually utilize an LS2/T56.
