    Results 61 to 67 of 67
      Rustburg, Virginia
      Quote Originally Posted by tnbandit View Post
      My work has a small hydraulic press that would do the job, but i'm not sure what kind of coupling to use to keep from damaging the bushings and ball joint. Maybe a similar sized socket?
      yes...I use a piece of pipe the same diameter to press in and a piece of pipe slightly larger underneath to press them out.
      Control arm bushings....Hmm, I used my 20T shop press on the lower bushings, but I swapped the entire upper arms out that came with new bushings. For the uppers, some use a 5/8" diameter threaded rod with large washers/nuts and such to press in and out without bending the arms.
      Fontana, CA
      Or the local tire shop should be able to do all the CA bushings and LBJs for 20-30 bucks.
      Nick R.
      Rustburg, Virginia
      Side note if pressing in the LCA bushing yourself....find a small piece of angle or something to help you keep from crushing the LCA bushing flanges....See pic of my LCA with Del-A-lum bushings...BTW, the bushings came from Global West and they included the piece of angle(pictured) in the bushing kit.
      May 2002
      Northern California
      good stuff john,
      every shop should have an assortment of pipe and tubing.
      holy cow its about time....Im waiting for the "I can't get the old bushings out" thread....
      I like to use an air chisle to collapse the inner circumfrence section of shell then the section that is inside the structure on the a arm, then try to get a section of the outside section on the shell part with the edge to stop it from going in too far...if done properly they will literaly fall right out. You can get the same results with a proper hammer and flat chisle.
      The ball joint...just cut the boot off and whack it with a hammer while arm body is supported on a table or 4x4. Falls right out.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2009
      The ball joint fell out last night when it all came apart. I'm going to work on getting the control arms loose tonight when I get home from work. Wish me luck LOL.
      May 2002
      Northern California
      Quote Originally Posted by a67 View Post
      You are really something else. You post a technique that can cause serious bodily injury and then joke about it. I was going to post some pictures of two hammers I picked up at a yard sale. A 4 # mini-sledge and a regular 10 # sledge.
      Both have fractures out of the faces and down the sides. Obvious what the guy did.
      And note that I never stated that the hammers would shatter. But that they will chip.
      But you don't need to believe me. Check out this link:
      http://www.finewoodworking.com/item/...hammer-strikes
      As I said, never hit one hammer with another. And make sure that you read to comments to the article I linked.
      Bob.
      actually Bob I am something else and its you that is making a matter of this. This was supposed to be a PM to you but since its out here I will aire it. humor<---
      Please: Re read what I posted and you will see that I had no idea what a rehammer or unhammer or whatever it was. I was speculating on what the definition was. Someone asked. I offered no deadly technique. No hammer-fu here.
      Another thing I find hinky is how one would get injured from shattering metal when one should clearly use safety glasses and a full face shield when the impacting of metals might be induced. Are we not using metal to impact metal? Seems redundently retorical.
      Joke about it? Jokes are funny, that comment was to be taken ironic with the past posts on this thread. Its not as deep as I usually get so it should have been clear. The amount of scatter being circulated was over flowing and I was trying to un agitate our OP friend. The matter was just mind blowing.
      If you knew me or have read any of my past threads you will clearly see that I will do my best to try to help someone that might need it. I am serious, I will spend hours, brain storn with collegues.... I don't care how many post counts you have, how much you contribute to the site, how many track days you have under your Simpson.... I will put forth ALL the cranial sucktitude I posses necessary to give aide or help along my fellow brethren to help fellow brethren come to an honest conclusion and get a possible problem solved just moved along dropping down the lonely tech section to be placed in a quiet archive just to be waiting to be pooped out for some member with a similar problem to help him with that ohh moment. <----light bulb
      I'm not here to show off my flashy new LED tail lights, my fantastical 3 link suspension I made in Allen's dog house using nothing but used bachelorete party favors or feed the project frenzied wading pool of slightly frozen jello...but to think I would give bad advice that could cause one to loose ones virginity is just preposterous but I will acknowledge your disgust and tip my hat to you and vow, it will never have to cross your 19" monitor this year. <--sarcasum
      I will never ever tell you how to think, I will just propose ideas that you can think about. We are all adults and we can make our own decisions.
      Please be know that I am aware of my spelling but please understand that I have a very heavy Philippino accent.<--humor
      but honestly the hammer deal. you can't always believe what you see on the internet. The mythbusters actually busted (<--pun-y) the hammer exploding hammer myth. I'd believe Cary Grant and Tory but in my heart I am sorry someone in cyber space was injured trying a barbaric method on hammer usage. I truly love hammers enough to not use them at the same time.
      Its a misunderstanding that just should not have to be mentioned but yes I went there....lets get together and help someone.
      Bob, please. Next time, pm me with a complaint like everyone else does. Most times its just read or typed out of context and just gets ugly with no other communication. Thank for being a great sport. And Cheers to TN bandit for getting it done.
      Sincerely Vince
      and JR...Mushroomed heads....hard on the tools...poop bag....I just don't know how to address this....silence might keep me out of trouble but it just because I am speechless. LOL My wife thanks you for that. LOL
      But if you were to walk in my shop you would also notice eye, ear, head, hand and body protection hanging all over the place. Never give the guys an excuss for not using proper protection.
      Mods please do not delete this, its my best work and I hate to have to cut and paste this into yet another thread. <---humor, please don't ban me...no really it is. It may take a few hours to soak.
      Aug 2009
      Well I like your humor Vince! And honestly humor keeps us sane sometimes with some of these frustrating project we dive into! Right? Or was it left? And as you said we are all adults and make our OWN decisions. No matter how many different methods we are suggested or told to try, we are still accountable for only ourselves and not everyone else. As nobody else is accountable for me, but me. Thanks again for ALL the advice and suggestions!
      78 Trans Am 6.6L,TH350, 3.08 posi, work in progress.
