Results 41 to 46 of 46
12-28-2010 #41
better then using grease grab a plastic from a bag of some sort put over the nut then push socket on the plastic covered nut.the plastic will wedge it in the socket and when you pull the socket off its not full of grease
IF your planning a tear down on a running engine you can add transmission fluid to the engine oil for like 15 miles and it helps loosen any sludge from the engine and make it drain to the oil pan for easier clean up and inspectionKacy
79 Corvette, 406 SBC, Holley EFI, 700R4
12-28-2010 #42
- Jul 2005
- Marshall , MO
- 699
Have a non magnetic screw to put in an awkward place? Use a wax ring used to seal a toilet to the floor dip the screw driver in it and the screw will stay on the tip of the screw drive makes less mess than grease.
Brad Shepard
69 Malibu
Marshall, MO
12-28-2010 #43Another one my dad showed me is filling a gas tank with a BIG jerry can the lazy way. (those 20gal ones get hard to hold up after a while).
You take a hose long enough to go from the jerry can to the gas filler neck, and place the jerry can higher than the gas tank. Usually you can open your trunk and put it in there.
Seal your hand around the spout of the jerry can where you stuck the hose in, and blow into your fist (leave the vent hole closed). The high pressure in the jerry can overflows the gas into the hose and down into the tank. Once it starts flowing it will keep going.
This is instead of sucking on the far end and getting gas in your mouth, yuk!
12-29-2010 #44
- Aug 2004
- Belle Plaine, MN
- 1,221
