    Results 1 to 20 of 22
      Jul 2007
      sweden
      i like mast..but...
      how about 6l80e or 6l90e at the same time as wideband I only want to know if itīs possible and if i get all the features as without the 6l80e
      someone told me wideband and 6l80e didnīt work or i missunderstood???
      iīm all for vvt
      camaro69-l92 with 6l80e considering mast ho cam 530hp - speedtech(LCA)-ats Street-Comp AFX-unisteer r&p - VariShock coilover QuickSet2-Hydratech Brake Booster - 5gen rear suspension
      movit brakes 380mm 6piston front-465mm 4piston rear - 275/30-19 front-325/25-20 rear 19x9f 20x12r cray scorpions
      Jul 2010
      Quote Originally Posted by holschen View Post
      iīm all for vvt
      I'm not sure about the wideband.. but the OEM computer will
      The L92 was used in the following applications:
      • 2007+ Cadillac Escalade**
      • 2007+ GMC Yukon Denali / Denali XL
      • 2007+ GMC Sierra Denali
      • 2008+ Hummer H2
      The 6L80E/6L90E was used in the following applications:
      So to answer the question of "if" the VVT will work in a L92/6L80E application is yes..
      My question is... Will the MAST control the 6L80E in the same way the OEM computer?
      Canada
      vvt
      Good thread. I bought my complete L92 about 8 months ago and there's already a lot more development and progress being made using VVT since then. Mine's just been sitting in a corner until I have time to dedicate to it and I was also waiting to see what became of the VVT in the aftermarket. I was always leaning toward keeping it.
      I'll be keeping my tko600 behind it and Speartech thought it would not be an issue since the tko has a vss for a reference signal to the ecm.
      I'm just sitting on the sidelines for now until I find a buyer for the BBC in the car and then it's full on for the LS.
      Apr 2007
      Nacogdoches, TX
      Quote Originally Posted by LS1MonteSS View Post
      Yes!
