    Results 81 to 100 of 222
      NJ/PA
      67 Camaro - Dad and Son build
      Well Ill give a bit of history on the car and will try to update as we go, have problems, questions ect. The car was a plane jane 1967 camaro that has been in my family since 1969. My grandfather worked for GM his whole life and in 1967 when the camaro came out a manager at where my grandfather worked got a 1967 camaro in butternutt yellow with a 327, powerglide and not to many options. Well in 1969 when the body was revised that manager wanted to get a 1969 camaro. So his 1967 was then put up for auction and my grandfather having 6 kids all around the driving age put a bid in of $200 for the car. Well as the story has it he won the car. My dad tells me stories of when my grandfather brought the car home and he wanted the car. The car was then passes along the girls (my aunts) up untill 1991 where it was then parked. My dad always told himself that one day he would have the car. Around 2000 me and my dad went and picked the car up from my aunts house. We picked at the car little by little not really knowing where to start. Up untill now.
      I have been doing alot of research and I think/hope these are going to be the final plans for the car. I will be getting pictures up the next time I am at the car. We plan on holding off on the body as it pretty much needs everything at this point and we have decided for this summer to try to tackle the mechanical stuff and make the car a great driver first. Please if you have some opinions/comments share. Input is always a good thing. The goal for the car is going to basically be a great cruiser with a couple of dragstrip trips in store and mabye road/auto course later down the road. We want to be able to run at least mid-low 11's with the car. Around 550-600 wheel. With that in mind..here is the current list..and the current wish list for the car.
      Current:
      LSX 454 GMPP crate motor
      FAST lsxr 102 intake
      FAST Fuel rails
      Nick Williams 102mm Throttle body
      C6 Front Accesory drive
      Mast Motorsport Oil pan
      S&P Motor adapters
      Energy Suspension motor mounts
      Energy Suspension Poly Kit
      Speed tech solid aluminum body mounts
      Custom subframe connectors
      QA1 front coil-overs
      Corbeau CR1 Front seats
      Forgeline DS3- 18 x 8.5, 18 x 12
      Wilwood 12.1 drilled/slotted -6 piston(front) 4 piston(rear)
      Ricks Stainless Tank (efi)
      Moser 12 bolt ( 35 spline, wavetrac, 3.73)
      prodigy 4 link w/ QA1 coil-overs
      DSE mini tub
      6 point custom cage
      Anvil Carbon fiber (cowl panel, header panel, front spoiler, hood, trunk)
      Wish list:
      T56 Magnum 6-speed kit
      Anvil Carbon fiber (rear spoiler)
      Stainless brake lines
      225-245/40/18, 335/30/18 tires
      Headers
      Wiring Harness, ecu, sensors, ect..
      Injectors
      Stuff for sale:
      Rs fenders(original)
      Cowl panel (original)
      Doors (original)
      ls2 engine covers (shaved)
      NOS gm 2" cowl hood
