Results 1 to 11 of 11
Thread: 350 Vortec trouble starting.
05-17-2010 #1
- Jun 2004
- Tacompton
- 750
I have a 350 Vortec engine in my 1999 GMC Sierra 2500 Classic and it has recently started having trouble starting. It is usually not on the first start of the day but, after you shut it down for a little while. It won't start on the first crank, usually on the second and then it idles very weak for two or three seconds. After that it idles fine and smooth right at 600 rpm. I have tried running fuel injector cleaner and that doesn't help. I also replaced the fuel pump and filter recently. Do you think it needs new injectors and if so how hard is it to do? Thanks and any help is appreciated as it is my daily driver.
1968 Chevelle 408 BBC,200 4r trans.
1987 Buick Grand National all original
1966 Chevy II Coupe 383 TCI Suspension
1969 C10 Custom FS/SB Daily
05-17-2010 #2
Starting The Transformation
- Sep 2008
- Kathleen, GA
- 159
maybe fuel pressure regulator..i'm bettin it's the pump
05-17-2010 #3
- Nov 2004
- Colorado
- 1,260
