Results 1 to 10 of 10
Thread: formula for calculating MPH
05-03-2005 #1
I ran across a formula that allows one to calculate MPH @ different rpm's with different transmission and rear end ratio's.
This formula would be helpful in selecting the correct rear end ratio
for your car.
MPH = (rpm X tire diameter) divided by ( *gear ratio X 336)
*gear ratio meaning: (rear end ratio X transmission ratio)
Does the math work? Is this a valid formula?
( I realize that top end is limited by h.p. and aerodynamics)
Scott
G Force Designs Concepts #004
"Quicksilver"
1965 Mustang Fastback
347/450hp FRPP crate engine,G Force T5
SSBC 4wdb,Budnik M5's etc...
SOLD
2011 GT500
Ingot Silver Metallic
Stripe delete
SVTPP/Elec. Pkg.
Stock for now
SOLD
70 Pro Touring Nova
572/620ho crate
TKO 600
DSE suspension upgrades
SOLD
05-03-2005 #2
- Aug 2004
- Vancouver BC
- 159
www.randysringandpinion.com is what calculator I use. Google search for engine speed calculators and you should find lots.
Cheers.
05-03-2005 #3I use this calculator all the time. Very Very accurate. Really fun to mess with to by pluggin in different gears like 3.42 or 4.11. Or check your speed in different gears of your 6 speed tranny. :3gears:
Richmond Gears CalculatorAdam_______Offical Car Name "ILLUSION"
05-03-2005 #4Is the formula I posted valid??
ScottG Force Designs Concepts #004
"Quicksilver"
SOLD
2011 GT500
Stripe delete
SVTPP/Elec. Pkg.
Stock for now
SOLD
70 Pro Touring Nova
572/620ho crate
TKO 600
SOLD
05-03-2005 #5Yes your formula works perfectly.
Originally Posted by steemin
Just takes longer and most people dont want to crunch numbers in case they make a mistake. But yeah it does work.
EDIT:
I used my car as an example. 4.11 gears, .50 6th gear tranny ratio
Approx 2,000rpm with 26" tires. Means im doing approx 69mph.
EDIT2 to help clearify which really isnt necessary but im bored at work right now.
69.136MPH = ( 52,000 ) divided by ( 752.13 )
*gear ratio meaning: (4.11 rear end ratio X .50 transmission ratio)Adam_______Offical Car Name "ILLUSION"
05-03-2005 #6I would also like to be able to check mph in 1st gear @ 6,000 rpm.
And rpm's @ 75mph in overdrive (.59)
I not sure that this can be done @ the "Randy's" site.
"Quicksilver"
SOLD
2011 GT500
Stripe delete
SVTPP/Elec. Pkg.
Stock for now
SOLD
70 Pro Touring Nova
572/620ho crate
TKO 600
SOLD
05-03-2005 #7Then you should click on the link I placed above. Its easy to do there. Gear Calculator
EDIT: Whats your rear end ratio in your car? Also need your tire diameter. Also whats your first gear ratio in your tranny?
I could answer almost any question you have with that info.Adam_______Offical Car Name "ILLUSION"
05-03-2005 #8
- Aug 2004
- Vancouver BC
- 159
Yes you can input for whatever tranny gear you want at randys site. It has tire size calculators as well so easy to convert.
05-03-2005 #9
