    Results 1 to 10 of 10
      Northern Indiana
      formula for calculating MPH
      I ran across a formula that allows one to calculate MPH @ different rpm's with different transmission and rear end ratio's.
      This formula would be helpful in selecting the correct rear end ratio
      for your car.
      MPH = (rpm X tire diameter) divided by ( *gear ratio X 336)
      *gear ratio meaning: (rear end ratio X transmission ratio)
      Does the math work? Is this a valid formula?
      ( I realize that top end is limited by h.p. and aerodynamics)
      Scott
      G Force Designs Concepts #004
      "Quicksilver"
      1965 Mustang Fastback
      347/450hp FRPP crate engine,G Force T5
      SSBC 4wdb,Budnik M5's etc...
      SOLD
      2011 GT500
      Ingot Silver Metallic
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      DSE suspension upgrades
      SOLD
      Vancouver BC
      www.randysringandpinion.com is what calculator I use. Google search for engine speed calculators and you should find lots.
      Cheers.
      Jul 2002
      Muskegon, MI
      I use this calculator all the time. Very Very accurate. Really fun to mess with to by pluggin in different gears like 3.42 or 4.11. Or check your speed in different gears of your 6 speed tranny. :3gears:
      Richmond Gears Calculator
      Northern Indiana
      Is the formula I posted valid??
      Scott
      "Quicksilver"
      SOLD
      2011 GT500
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      SOLD
      Jul 2002
      Muskegon, MI
      Quote Originally Posted by steemin
      Scott
      Yes your formula works perfectly. Just takes longer and most people dont want to crunch numbers in case they make a mistake. But yeah it does work.
      EDIT:
      I used my car as an example. 4.11 gears, .50 6th gear tranny ratio
      Approx 2,000rpm with 26" tires. Means im doing approx 69mph.
      EDIT2 to help clearify which really isnt necessary but im bored at work right now.
      69.136MPH = ( 52,000 ) divided by ( 752.13 )
      *gear ratio meaning: (4.11 rear end ratio X .50 transmission ratio)
      Northern Indiana
      I would also like to be able to check mph in 1st gear @ 6,000 rpm.
      And rpm's @ 75mph in overdrive (.59)
      I not sure that this can be done @ the "Randy's" site.
      Scott
      "Quicksilver"
      SOLD
      2011 GT500
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      SOLD
      Jul 2002
      Muskegon, MI
      Then you should click on the link I placed above. Its easy to do there. Gear Calculator
      EDIT: Whats your rear end ratio in your car? Also need your tire diameter. Also whats your first gear ratio in your tranny?
      I could answer almost any question you have with that info.
      Vancouver BC
      Yes you can input for whatever tranny gear you want at randys site. It has tire size calculators as well so easy to convert.
      Newbury Park, CA
      Try setting the formula into an Excell spreadsheet. This way multiple columns can be made using differing gear ratios, tire heights, overdrives, etc.
      Northern Indiana
      Thanks for all the reply's.
      I just wanted to make sure that the math was not flawed with the formula that I was using.
      Scott
      In regards to specifics of "the car". This is a car that is currently being built and I hope to close the deal and finalize the details in the next week or two.. If I purchase the car I will be able to select the transmission and the rear end ratio.
      "Quicksilver"
      SOLD
      2011 GT500
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      SOLD
