    Results 1 to 15 of 15
      Dec 2009
      aluminum 9 inch housing
      Hi all,
      My first post here so be nice! I'll get round to posting something in the intros shortly (wrong way round I know), and a give a few car details there.
      To cut a long story short, part of my long term plans for my Cortina is to prep it for fast road and occasional track day use (circuits not drag racing).
      I'm considering a currie/strange aluminum 9" housing, but just wondered if the axle tubes are still steel? I presume they are so that ends can be welded on etc.
      Therefore how are they fitted into the housing / pumpkin? Are they essentially a press fit?
      Cheers guys.
      Jono
      Car:
      Mk3 Ford Cortina GT (2dr)
      (England's Mini Muscle car)
      San Antonio, Tx
      yes the axle tubes are steel. i had one in my last car i built and loved it. yes they are pressed in and then there is 6 IIRC set screws per side. if it wasn't for building a 3 link in the new project i would install one again for sure.
      Instagram: CamaroAJ
      Ontario, Canada
      Any idea as to how much lighter the entire housing is with the aluminum center?
      Ken
      My other car is a Vega.
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by Kenova View Post
      Ken
      Yeah, Im interested also. Whats the weight savings and are there horsepower limitations?
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      Mar 2010
      Central IL
      Are you talking about the Strange aluminum gear case and standard housing or the Strange and Currie aluminum housing.
      If you are talking both being aluminum then I say go standard there really isn't as much weight diff as you would think the Al has to be much thicker to give you proper strength and much of the weight savings is lost. No to mention with the required gusseting that is built into the housing you are limited with what you can do as far as setup/modifications.
      I am biased though as I prefer a 3-link with watts link which would be much more difficult with the Al housing so I prefer the stronger F9 fabricated housing for the same money.
      Sean
      The difference between stupidity and genius.... genius has limits
      san diego
      I have a moser aluminum gear carrier in the 65 mustang. They reccommend it for drag and little stret use. They are not designed to take starting and stopping forces.
      Dec 2009
      I was asking about the housing not the gear carrier, but was intending to use both the strange/currie ally carrier and ally housing.
      https://www.pro-touring.com/forum/sh...ad.php?t=41675
      This thread mentions the weight differential (no pun) between the steel and aluminum carrier (33lb vs 13.6lb), but not the housing.
      I can't find anything on the currie site about the weight of the housing, so suspect LSx_88_Ciera is right and there is not much difference.
      I'm keen to reduce unsprung weight but not at any cost so if anyone does have info on any weight savings to be had from using the aluminum housing I'd be pleased to hear.
      For info I'm hoping to use SBF (302/331/347 etc) probably no more than 400hp, but this will come later when the rest of the car is ready and I can afford it. For starters it will have to stick with the V6 it currently has which will certainly not trouble a nine inch diff.
      Use will mostly be road, with 2 or 3 circuit days a year. not intending any serious drag race use.
      Falcon65, not sure if I've misunderstood, but did you mean that moser do NOT recommend drag use for their alloy carrier?
      Thanks for replies so far
      Jono
      Car:
      san diego
      moser only recommends the aluminum carrier for drag racing. Road racing is too hard on it; so a reduced life span.
      Dec 2009
      Fair enough.
      While we're on subject of the carrier, am i right in thinking that the one sold by currie is actually Strange?
      Jono
      Car:
      San Antonio, Tx
      the shipping weight of the aluminum houseing was 40 lbs. that was just the houseing with no axles in it. assembled i could pick up the whole thing with out a problem. made putting it in the car a breaze.
      this is what i'm talking about. http://www.currieenterprises.com/ces...E.aspx?id=1567
      Instagram: CamaroAJ
      Dec 2009
      Thanks for info CamaroAJ. What sort of use did your car get (street/strip/circuit?), and did you notice any problems? did you use aluminum carrier as well? I'd assume that would be better choice if using alu housing as any heat expansion between the two should be similar?
      I'm not looking to three link so shouldn't be an issue for me (going for six link, (four link plus chassis mounted watts linkage).
      Jono
      Car:
      San Antonio, Tx
      autocross/street and road track. i never got it out to the road track. the new owner has taken it to mid ohio a few times with no problem.
      yes it had strange aluminum 3rd member.
      Instagram: CamaroAJ
      Dec 2009
      Not the same housing, but there's a listing for one here at 15lbs 8oz.:
      https://www.lefthanderchassis.com/vi...roduct=0145243
      The only comparative listing for steel center sections is at currie:
      http://www.currieenterprises.com/ces...e.aspx?id=1142
      Sadly, they list the weights of the various units they offer, but have no reference for what a stock one would weigh. (I also note the housing from Lefthander is cheaper than the steel currie ones.)
      Interesting that they found a nearly 20lbs difference between the casings, Preston posted up a difference of about 10lbs on Corner Carvers:
      http://corner-carvers.com/forums/sho...gh*#post767258
      Mind you they were loaded, but each with a lsd or atb style differential. Maybe differential weight itself is something to look into.
      Dec 2009
      Good info, cheers.
      Moving slightly from my original question, I'd been considering a full floating set up, I presume there's no reason you can't do that with aluminum housing? Or is there?
      Jono
      Car:
      Dec 2009
      Full floater should be fine. The axle tubes would still be steel, so AFAIK you'd just weld floater ends to the tubes.
