    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 58
      May 2006
      Rhode Island
      Is there an LS1 conversion kit for the rear?
      I just bought an LS1 conversion kit and some calipers for the front of the firebird, but my question is does anyone sell a LS1 conversion kit for the rear? I can't seem to find one, or do i just need a bracket like the one below and supply the calipers and rotors? I'm not 100% sure what rearend is in the car, all I know is it was originally a straight six car, so I'm sure its one of GM's weakest rearends, if that matters. thanks for any help.
      Rene P.
      Nothern California
      Tobin at KORE3 is your best call to make on these items.
      http://www.kore3.com/
      Email: [email protected]
      Orders: 800.357.5467
      Tech: 541.924.5673
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
      Feb 2007
      Vancouver, WA
      Factory LS1 brakes are about as close to a bolt-on swap as there is. A minor amount of fabricating is necessary, but nothing terribly difficult. The real advantage of the LS1 swap in my opinion is the excellent drum-in-rotor hat parking brake. The brakes themselvers are excellent as well.
      Here's a writeup I did on the swap at Team Camaro.
      http://www.camaros.net/forums/showthread.php?t=161383
      May 2006
      Rhode Island
      Quote Originally Posted by gort69 View Post
      thank you Al. In your spacer section you mention that it goes between the LS1 backing plate and the axle flange, my question is where did you find the LS1 backing plate, I can't seem to find them anywhere. I can find the calipers and rotors and thats it. Can I use a bracket like the one pictured above? I'm sorry, I'm a total newbie at this.
      Rene P.
      Mountain Springs, Texas
      Quote Originally Posted by 68firebird View Post
      BRP Hotrods sells them on their website and also on ebay.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2009
      look in the classifieds section of LS1tech.com or on ebay. i got my backing plates off ls1tech there are usually quite a few cars being parted out..
      May 2006
      Rhode Island
      Ok guys, I'm in negotiations with this guy on ebay, is $195 shipped for these complete rear brakes a good price?
      Rene P.
      Feb 2007
      Vancouver, WA
      Well it's an "OK" price. Personally, I wouldn't pay to have rusty old crappy rotors shipped across the country. For the price you pay to have the extra weight shipped you'd be well on your way to buying new rotors at your local parts house. They aren't expensive.
      You also have to remember that your 68 bird has staggered shocks. Some have made it work using a R and a L LS1 backing plate. I used two Ls, so essentially had to buy two sets, as it's hard - but not unheard of - to get just one.
      Somewhere in the article I linked is another link to GM part numbers. The backing plates are still available new AFAIK - not sure on the prices. Here it is http://www.poltergeist.us/page/Elky/.../ls1brakes.htm
      PS In the write-up I linked, I said 3/8 seems to be be the most common thickness for the spacer. Scratch that, I meant to say 3/16".
      May 2006
      Rhode Island
      K, I'll skip on that then, thank you. I'm gonna try and find those damn backing plates.
      Rene P.
      Feb 2007
      Vancouver, WA
      Yeah, if you're not in a rush you can do better. I pulled a complete set of rears off of a low mileage '00 for $100. Craigslist deal.
      Houston, TX
      If you're not in a hurry, wait for it on ebay. I bought mine for $90 shipped, minus the rotors.
      Tu Ho
      Firebird V2-LS swap
      May 2006
      Rhode Island
      Quote Originally Posted by rickpaw View Post
      yea, I'm not in a rush, so I'll keep an eye on ebay and at the same time keep browsing other companies rear conversions. thanks guys.
      Rene P.
      They are on ebay for $39 from BRP Hotrods:
      http://cgi.ebay.com/ebaymotors/10-12...Q5fAccessories
      They aren't backing plates. Just a spacer. Which I am not sure are even required. After removing the drum brake anchor portion of the flange and re-drilled the holes. I've bolted stock LS1 backing plates right to the tube flange of corporate 10-bolts.
      Note that in the Team Camaro thread that conversion required a .180 - .200 spacer between the backing plates and the tube flanges. Although the installer didn't mention whether the rear was the early 10-bolt or a 12-bolt.
      Bob.
      Feb 2007
      Vancouver, WA
      It's an 8.2" 10 bolt from a 68 Camaro. My understanding is that the early 12 bolts are the same.
      I mentioned in the write-up that some don't use a spacer at all, and to mock it up and have a look see. Mine was definitely in need - the rotor would have grazed the abutment, or at least very close, I forget exactly.
      Have read that the axle plant wasn't terribly consistent in where the flange was welded in relation to the axle face.
      Being that it's a floating caliper probably not necessary to get it dead nuts centered, but as close as you can.
      The spacer - if needed - not only centers the rotor in the abutment, it also properly locates the e-brake shoe in the rotor hat.
      I'm switching to an 8.5 10 bolt from a 79 Nova in a month or so, and will re-visit that part of the swap.
      Oregon
      Not to make things more complicated, but it makes a difference if you're working with a BOP 10/12-bolt with positively retained axles versus a 10/12-bolt with c-clips. The center hole on the LS1 backing plates is 72mm [2.835"] and the BOP axle bearing has only a 2.75" outside diameter. What this means is that you'll need to machine a spacer to go between your original retainer (assuming it can move outward on the axle far enough) or machine your own retainer. Anything that isn't an open "C" profile or two pieces will require the removal of the axle bearings for installation.
      Tobin
      KORE3
      It's what I does.
      Westminster, MD
      I was looking at these as well. In the item description they mention an available inboard shock mounting kit they have allowing the use of both L & R calipers.
      Ed Cooney
      '96 Buick Roadmaster Estate Wagon, LT1/4L60, full bolt-ons & Solomon's tune, 18" Ridler wheels, lowered with Belltech springs
      ‘70 Buick Skylark Convertible project w/ GN drivetrain
      '91 Formula, pending track day build
      Those spacers are needed to take up the space of the original drum backing plates. Im abit frugal so a couple $'s worth of washers work just fine too.
      Quote Originally Posted by Apogee View Post
      Tobin
      KORE3
      When I swapped the blazer rear discs onto my olds 10bolt my first thought was similar to that. The other brain storm I had was that I found everything bolts up perfectly by slotting the axle retainer to remove it so the disc mounting plates can be installed on the axle first and bolted to the outside of the axle retainer.
      St. Pete FL
      Ed, that is correct but I don't see it listed on their web page anymore :( I have it on my car (& may sell it b/c of the $$$ suspension parts I got) so if you need pics LMK & I can try to post some.
      HELP!!!
      Aug 2009
      FYI, I wouldnt waste your money on the BRP spacers. I just did this conversion on a 70 chevelle 12 bolt and the spacers did not center the abutment. I still ended up having to add washers to get centered. May as well just save $40 and make your own spacers. And, on the chevelle I mounted the calipers and backing plates on opp. sides so the Ebrake levers would pull forward.
