    Results 1 to 20 of 23
      Lake Oswego, OR
      ATS Steering Arm bolts
      I just got the ATS spindles on my car. When I go to bolt on the steering arms I'm getting a lot of resistance with the bolt shank going through the arms. I can tap them in, but it seems they're tight enough that they would not turn easily. Am I missing something? Also, in the directions off ATS' website it says "Note that there are two
      different length steer arm bolts with the longer of the two used in the rear." All 4 bolts I have are the same size. Anyone else experience any if these issues?
      Lee
      1966 Cutlass
      The difference between truth & fiction: fiction has to make sense.
      Build Thread:
      https://www.pro-touring.com/forum/sh...ad.php?t=64470
      Mountain Springs, Texas
      At least you got bolts with yours. Mine came with none. What a PITA, I have no idea what sizes are needed.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Lake Oswego, OR
      It says H-K USA 1/2-20 on my bolt heads--hope that helps.
      Lee
      1966 Cutlass
      Build Thread:
      So. Cal.
      Thats good that they are tight. Various bolts have some thickness added due to the coating.
      Are the arms steel or aluminum? If they are aluminum the anodizing may be causing the tightness. But more likely its the coating on the bolt.
      It may just take a quick swipe with some 220 grit sandpaper on the smooth shank of the bolt to knock down any rough spots on the coating. Knock down the rough coating (black oxide coating can be rough) a lil and lube the shank up with oil. It will prolly turn just fine. You want the shank of the bolt TIGHT in the bore of the arm. They did a good job if its tight. The bolt shank just needs to be polished up a lil. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      St George Utah
      all you have to do is call.
      the bolts should be 1/2 x 2.5 and 2.75 NF socket head cap screws.with slim line locking nuts.
      i don't know whae you ordered yours Don but all the spindles "Should" come with bolts. if you ordered the steering arms seperatly they would not have come with hardware.
      currently we zinc plate the bolts,(i see yours are not) and that combined with the anodizing will cause a tigth fit. but that is good.
      call if you have an issue
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Lake Oswego, OR
      Thanks JRouche.
      Blake, I'll talk to you tomorrow.
      Lee
      1966 Cutlass
      Build Thread:
      Blake, my spindles and arms were shipped just before the Speedtech buyout and as such I am pretty much on my own.
      St George Utah
      why don't you give me a call i am sure we can fix you up!!
      1-888-467-1625
      Blake Foster
      435-628-4300
      St. George Utah.
      Quote Originally Posted by killer69 View Post
      1-888-467-1625
      That is top notch customer service right there when you are taking care of someone else's customer. I will give you a call.
      Spoke with Blake today. Great guy, he is sending me the steering arm bolts no charge.
      Don
      Feb 2010
      Chico, Ca
      I just looked at my ATS spindles that are still in the box and they didn't come with any bolts either...I bought them through Classic industries
      St George Utah
      give me a call
      Blake Foster
      435-628-4300
      St. George Utah.
      Rustburg, Virginia
      WTG Blake.
      Indiana
      Don
      Now that right there will bring in new customers. Until I read this thread, I wasn't aware of Speed Tech Performance but I am now! I have a set of ATS spindles and steering arms I bought from Tyson just before he closed the doors so I'd have them when I wanted them not knowing they would be available through other dealers. Anyway, I think I might need some hardware as well. Now that I know there's a good source for hardware, I feel better. Thanks!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Jun 2009
      Cassopolis, Mi
      Also mine were purchased from SCandC and did not have bolts shipped with them.
      Auburn, CA
      Hey...I got the bolts but no arms!
      Just kidding!
      Tim Tracy
      St George Utah
      WOW
      it would "appear" the NO one got bolts!!!
      if you need bolts you will have to call me and i will start a list.
      TT302Z28. i don't know if i can HELP YOU........... lol
      Blake Foster
      435-628-4300
      St. George Utah.
      Southern Indiana
      UHMMM LAST I HEARD TT302Z28 WAS BEYOND HELP PERIOD! But thats just rumor too.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Rustburg, Virginia
      Quote Originally Posted by TT302Z28 View Post
      Just kidding!
      No arms?....so...you're gonna need some help putting the bolts in? LOL
      Feb 2010
      Chico, Ca
      Hey Blake I never received the bolts and was just wondering if they have been sent out yet... thanks again
      Nevin
