    Results 1 to 10 of 10
    Thread: procharger ?
      Nov 2009
      procharger ?
      how hard can I boost my 355 sbc wit a non intercooled procharger?
      Aug 2008
      Hutto, Texas
      Too many factors: Fuel octane, cam, compression ratio, timing, carburetion or fuel injection, etc. On their site, ProCharger has a chart showing approximate boost allowed with/without an intercooler.
      Honey, I don't know how those black marks got on the driveway....
      UK London
      Quote Originally Posted by 64malibu View Post
      Depending on all those variables mentioned above 6 - 12lbs give or take. Maybe more if you have a carb or meth/water injection. The real limit is often your pistons, crank, gearbox or diff........ If you can live with 6 - 700hp and not get on it fore more than a few seconds at a time the stock 355 block could last years. Mine did although it had TRW forged pistons!!!!
      Jul 2008
      ATL
      http://www.procharger.com/intercooled.shtml
      Depends on your compression in your engine.
      I just removed my air to air intercooler for road racing - but I turned my boost down to 5 psi - so I am way under the curve which with my 8.5 to 1 compression I can run 10 safely without intercooling. I can probably push more since I have all billet internals so damaging them is a bit tougher but why live on the edge.
      HPDE is the greatest thing since sliced bread.
      So much to learn......so much $$ to do so lol
      Socal, Ca
      Quote Originally Posted by wicked68 View Post
      Why did you remove your air-air for road racing?
      Jul 2008
      ATL
      Quote Originally Posted by DJW32 View Post
      yes - it was too much area in front of my radiator for proper cooling of the engine.
      UK London
      Try leaving a gap between the back of the A/A and the front of the radiator. Is your A/A in front of the radiator support. If not get it modifiyed to clear the hood latch a bit like Larry's TT 1st Gen. There are plenty of A/A Procharged Camaro's hitting the streets and long hot traffic jams.
      Having said that I'm now going to water/meth injection. Due to filling the radiator space with Prochargers!
      Jul 2008
      ATL
      Quote Originally Posted by Procharmo View Post
      its fine in normal driving. I lost a fan at the last race and it overheated.
      with 2 fans it might be ok but there is a big difference in running 5000 rpm for 20 miunutes straight
      what is a/a ?
      Dunwoody, GA
      air to air intercooler or a/w which is air to water.
      I can imagine you had air flow issues. The front opening on a Mustang is so small. Is there enough room to maybe make a custom core support with a much larger opening? Or maybe heat extractors since you have those huge fenders with a bunch of space under them.
      Trey
      ~ Jon Hammond
      Jul 2008
      ATL
      Quote Originally Posted by WS6 View Post
      I have a huge front opening - I redid it custom for massive intake.
