      BMR Launches New Product - 67-69 F-Body Convertible Tunnel Brace
      BMR Fabrication
      Driveshaft Tunnel Brace for 1st Generation F-Body Convertible
      Stiffen up the chassis for much improved handling in your convertible 1st Gen F-body with a Driveshaft Tunnel Brace from BMR Fabrication. Manufactured from 1/8” CNC laser cut and CNC formed steel, this driveshaft tunnel brace replaces the OE stamped unit with a much stronger version. The BMR Driveshaft Tunnel Brace (DTB003) features a gusseted design that bolts to the original mounting holes yet provides an additional 2” of exhaust clearance without sacrificing ground clearance. No welding is necessary. Provided with new grade 8 mounting hardware. Installation time is only 30 minutes. Available in black hammertone or red powdercoat.
      To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email [email protected], or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
      Houston, Tx
      What does this thing bolt to? The sybframe body mounts? I assume it could be used in a coupe to further stiffen the chasis right?
      Jun 2009
      Quote Originally Posted by Taylor1969 View Post
      It fits the convertible only. The convertible models already have a reinforced floor pan that ties together across the tunnel with a bolt-on factory brace. Our brace replaces the OE brace, providing more strength and more exhaust clearance. Without extensive fabrication, it would not be possible to use this brace on a hardtop car.
      OE brace above.
