    Results 1 to 17 of 17
      LI New York
      POR15 Glisten PC ?
      Anybody use this stuff? I'm looking to get a new intake manifold and want it to look nice. I have a few options and so far this looks the best. I don't want it to yellow if gas gets on it. The first one I was looking at was the Endurashine that cost around $350. I've read it yellows. The second is polished that cost $420. Big $$$. The last is a standard manifold that cost $199. (Victor Jr). Then I could coat it for $40.
      http://www.por15.com/GLISTEN-PC/productinfo/GPCGG/
      Feb 2003
      St. Louis, Missouri
      I haven't used that particular product from POR, but I can tell you that the regular clear over unpolished aluminum will yellow and consequently look shatty.
      Rick Butterfield
      LI New York
      Quote Originally Posted by Happyfunballs View Post
      What do you mean regular? This is a 2 part epoxy.
      Sep 2001
      Accord, NY
      I've used the Glisten PC with good results. No yellowing and durable.
      68 camaro - SOLD
      LI New York
      Quote Originally Posted by Rick Dorion View Post
      Anyone know what size spray tip I should use?
      Sep 2001
      Accord, NY
      In my case I brushed it on and it flowed out. This was on a gas tank but the finish was very smooth.
      68 camaro - SOLD
      Oct 2006
      Morristown, NJ
      Off topic, but what is with this warning.
      WARNING: THIS PRODUCT CONTAINS ETHYLBENZENE - A CHEMICAL KNOWN TO THE STATE OF CALIFORNIA TO CAUSE CANCER
      Does this product only cause cancer in California.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Sep 2009
      did this on my blue 73 and has not yellowed after 6 years and im going to do my friends and another this weak.
      Feb 2003
      St. Louis, Missouri
      Quote Originally Posted by mnm99 View Post
      POR has a regular clear topcoat(without catalyst) that is UV sensitive and will yellow out....even on a transmisson that never sees the sun.
      Rick Butterfield
      LI New York
      Quote Originally Posted by 732ndgen View Post
      Did it come out nice? Glossy? Did you brush or spray it on?
      Sep 2009
      it was glossy and I brushed it on,it came out smooth clear and glossy Im going to try to spray the next ones.I was going to order from summit again but the shiping was $9.99 so I called my locall paint store and they got it for me in 1 day.you can get it in gloss or flat.good luck (glisten is a 2 part system the clear and a hardner)
      Jun 2009
      Pensacola Fl
      JUNK, powdercoat or use a good clear. That stuff will yellow in no time!
      LI New York
      I called back POR15 and a new tech DID NOT recommend using it. He was concerned about the heat and yellowing. Well that leaves me a clear coat or polished manifold. I don't know.....
      Jun 2009
      Pensacola Fl
      Powder coat!!!
      LI New York
      Quote Originally Posted by rrstroker71 View Post
      Powder coat!!!
      I heard that yellows too.
      Jun 2009
      Pensacola Fl
      Never had that problem unless you have a gas leak issue. Been doing it for a couple years now.
      Jun 2009
      Pensacola Fl
      Never had a problem unless you have a fuel leak. been doing it for a couple years now
