Panhard rod for 2nd gen. firebird?
So, I took the '79 Trans Am 455 to my first autocross event, SCCA Solo2, at the Michelin test facility and was thoroughly humbled. In mountain driving I always thought the car handled well, so this event was an eye opener. Granted I'm running 245-60/15 BF Goodrich Radial TAs, but somehow I thought that the car would fare better. I have Addco swaybars, poly mounted, Coil Spring Specialties drop coils, Flex-a-form composite leaf springs rear, KYB gas shocks, Comp. Eng. subframe connectors bolt-in style welded in. It felt fast and precise in the slalom, but in the curves it became a real tire-sliding handful.
Now, reading the instructions for Vette Brakes and Parts, the other guys that make composite leaf springs for f-bodies, I read this: "In racing or autocross applications, a pan hard rod is required for lateral strength." Hmmm.
With the Flex-a-form springs the car is jacked up, so that might contribute to the problem, but does anyone make a panhard rod to locate the rear axle, or is this something I need to fab up?
Any suggestions to make the car better for autocrossing is also greatly appreciated.
