      Norwalk, Ct
      Country Flag: Wales
      What size AN hose for radiator?
      I'm using a true 16AN top radiator hose on my car, and would like to convert the bottom as well.
      Not sure what size i need to use...16 AN seems a little small, so maybe a 20 (but then I can't use black fittings/nylon braided hose that I have on top). Anyone have experience/done this?
      Nick
      Nick Townsend
      Pro-Vintage 69 Corvette
      64 Riviera Custom - 20's, air bags
      Shell Valley Cobra
      2005 Penske Racing Dodge Charger Nextel Cup Car "Rusty's Last Round"
      Henderson,NV
      I don't know your application but normally the lower hose is slightly larger than the top hose. I'm sure GM engineered it that way on purpose. 20an might be to small.
      Todd
      Melbourne, FL
      I've seen some use -24 for bottom and -20 for top.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Aug 2003
      16 and 20 are minimum
      Norwalk, Ct
      Country Flag: Wales
      I spoke to Meziere and my waterpump (chevy small block) inlet fitting is basically designed for 20AN, so I should be ok using a 20 AN on the bottom.
      Nick
      Nick Townsend
      Shell Valley Cobra
