    Results 1 to 20 of 36
      Apr 2007
      Odenton MD
      Project "Ooh $#!+"
      Its a 1979 Trans Am... I bought it with no motor no trans no seats.. The body was over all in good shape only a couple of rust spots on the fender and pass side floor... Other than that a solid starting point
      Plans so Far
      1998 LS1 /w 4L60e picked that up a week ago... (using BPR motor mount kit not sure what I going to do for transmissin cross member was thinking of using stock one just moved back)
      Sent the harness to LT1 wiring last week (should be done by next week)
      For brakes I am doing C5 up front not sure what I am doing for the rear
      I order SC&C upper and lower control arms
      I have wheels 20x10 rear and 18x8 fronts no tires
      I removed the subframe and started cleaning it up and getting it ready for the new parts.....
      May 2006
      Rhode Island
      from the pic the body looks to be in great shape, good luck and keep posting up pics as you go!
      Rene P.
      Dec 2009
      St. Louis, MO
      BRP sells the crossmember too. I got the whole "kit" for my car...it's made for a 4L60E. One note, I did have to notch the frame slightly where the crossmember goes to get the correct pinion angle.
      Tim
      1972 Camaro
      St. Pete FL
      She does look to be in good shape. It will be a cool ride when done.
      For the rear (& depending on your budget) you can go with the stock setup that came on the LS1 camaro & firebirds. BRP sells the adapter plate for $40. If you want bigger you can go with the vette stuff or Wilwood. 1979 was the 1st year for rear disc on firebirds so you could also just get some drilled or slotted stock disc to match the C5 rotors you are going with.
      What other mods are you doing (suspension, interior, etc)?
      HELP!!!
      Apr 2007
      Odenton MD
      For the rear I am going to get Pro Touring F-body spring front and rear... With soild body bushing and subframe connectors...
      My goal for the next few weeks is to get everything all cleaned up and back to a clean roller... Then I will start on installing the power train...
      Interior still unsure on that want to do a 4 gen set up but want to keep things clean and simple ( trying to stay away from the cheese factor)
      Dec 2007
      Nice project what color is that?
      The car looks good and sounds like a nice project. Good luck with it.
      St. Pete FL
      Pro Touring F-body has some good items & he knows his stuff
      What about the front end?
      HELP!!!
      Apr 2007
      Odenton MD
      Quote Originally Posted by avewhtboy View Post
      not sure what color that is but its not staying
      Apr 2007
      Odenton MD
      front is getting sc&c upper and lower control arms
      St. Pete FL
      Mark knows his stuff too. Good choices for both
      HELP!!!
      Apr 2007
      Odenton MD
      Quote Originally Posted by cdoggy81 View Post
      Did you get that GTO dash to fit in the car.... I was thinking about doing that with 4th gen stuff
      good luck with the nice project!
      St. Pete FL
      Not yet........
      but my friend Aaron has already done it with the 4th gen stuff. It fits really good too:
      HELP!!!
      Apr 2007
      Odenton MD
      is he using the 4 gen fatory guages too
      Birmingham, AL
      That 4th gen dash almost looks made for the car. How much work do you think he has in it to get it to that point?
      Stephen
      Apr 2007
      Odenton MD
      Got my upper control arms in today.... Hopefully this will give me the push to finish up cleaning the subframe
      Apr 2007
      Odenton MD
      This last week I have not made any head way on the car... But I have been ordering parts and planning this build out a little more.... I order a custom works c5 brakes kit I am using ls1 calipers with c5 abutments... I also pulled the trans am dash, and sent the guages out to be wired with the rest of the harness
      Apr 2007
      Odenton MD
      The motor I bought was DOA... But I was able to find a 2000 vette motor with very low miles.... I should be get my harness and ecu back here in a few days.... Over the past few weeks I was able to get the front subframe complete
      Apr 2007
      Odenton MD
      rotors are just for mock up
