      Feb 2010
      GM A Body spring help
      I have a 1972 Cutlass Supreme and just upgraded the wheel and tire combo. I would like to lower the rear end a little more. I have upgraded to all polyurathane bushings and hotckis 1" lowering springs and shocks but still not satisfied. Would like to lower another 1"-1.5". Please help. On a budget airbags not an option unless cheap.
      Jun 2009
      Southwest Florida
      Loosen and retorque all the suspension bolts when the car's weight is on the wheels, and let it settle for a few weeks. If you've done that and it's still too high, trim a quarter coil or so from the springs and repeat until you get the ride height you're looking for.
      -- Dan
      Oct 2005
      Orlando, Fl
      You could also go with a circle track spring. I'm running an 11" spring in the back, but they also make a 12". They are about $45 each.
      Make sure the suspension isn't preloaded like Yoda said. chevelles.com pro-touring section has a bunch of spring info.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Oct 2008
      Florida (Tampa Bay Area)
      Dmitjoe....post up some pics and let us all see how it's sitting.
      Kyle
      1972 Oldsmobile Cutlass Supreme:
      Hotchkis TVS
      SC&C Stage II+
      SPC Tubular Lower Control Arms
      Rushforth Super Spokes 19/20 brushed/polished
      Olds 455 Build
      200-4R Transmission (CK Performance Full Billet Pro Street/Strip)
      10bolt 8.5" w/Truetrac, 3.73 gears, Moser 30spline axles
