    Results 1 to 7 of 7
      Sub frame bushing question
      Guy's was putting some global west sub frame bushings in my 69 camaro and noticed something tonight,the thickness of the male bushings that go at the back of the subframe and the middle not the core support.Two of them are are thicker than the other two far as the male part that slides thru the top of the subframe between the body and subframe,is this suppose to be like this,I put the thicker one in the very back and the thin one by the firewall which just didn't seem right,any ideas.THANKS!
      Ok just went to the global west web site and saw that they offer bushings that lower the body 1/2in,i ordered them thru summit and may have got the wrong one's,if this is so has any one used these.THANKS!
      May 2002
      Northern California
      I believe the thicker ones go on the firewall points.
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2009
      El Dorado Hills
      I'm not really clear on what your saying, but it sounds like you bought Global West 1/2" drop body mounts from Summit but intended to get the standard height mounts. If thats the case, I am using the Global West solid 1/2" drop mounts on my car and will check for you in the morning.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      Thanks guy's.
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by Fillpot View Post
      The thinner one gets sandwiched between the body and the frame at all points. Good luck!
      Gaetano Cosentino
      Thanks for all the help guys but I figured it out,big dummy here ordered the 819 kit or something and was suppose to get the 800 kit,the 819 works with sub frame connectors or something,my mistake.THANKS!
