      Need input on carb adjustment
      Hey guys I sent my eldelbrock q-jet to cliff's for a rebuild. My car is a 71 cutlass with a stock 350.
      First what would the factory air/fuel mix screws setting be?
      And it was running fine under load when I put it on except at idle it smelled rich and had a rough idle, then I started screwing with the mixture screws now it smells rich idles even worse and throttle response is not as crisp.
      Right now I'm set at 4 turns out from the bottom, anybody have a suggestions and where I should be set at? Cliff said this carb is a 1910 and was way to big so he lowered the jetting and set it at 3 turns out.
      Jeff
      Dec 2009
      El Dorado Hills
      I am not familiar with Edelbrock carb,s, but the first thing I would do is check the float level. Once your sure that is correct I would start playing with the air bleed screws and get it to idle decently. Once it was idleing descent I would check the timing. Once the timing is dialed stay with the carb until you have corrected the problem.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      Apr 2008
      Newark, OH, / Concord, NC
      Try this guy, he's the best on Q-Jet style carb that I know of
      Dale
      <LI class=g>Best vintage carter WCFB restorer ?? - Lateral-g Forums
      VAL HEADWORTH comes to mind...........those guys are the nuts for what your looking for.. His phone should be 660 385 5236 ...
      www.lateral-g.net/forums/showthread.php4?t=14291 - Cached
      Jeff
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Rustburg, Virginia
      Keep an eye on the fuel pressure...those needles and seats don't like much above 5.5-6psi and they just won't hold the fuel back while idleing.
      Thanks for the reply guys, tomorrow I'm gonna pull it out and play withnit a little more.
      Jeff
      Henderson,NV
      4 turns will make it pig rich at idle unless your idle feed restrictors are way to small. Start with 2 turns and go from there. You can use a vaccum gauge or rpm to tune for the cleanest idle. The highest vaccum and or rpm nets you the cleanest idle. Then you can fatten it a hair from there to get your drivability.
      Todd
