    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 164
      May 2009
      Quote Originally Posted by Gitter Dun View Post
      I just got back from dropping engine back in. I have a System One remote oil filter with removable filter screen checked and cleaned it before dropping engine in. I didn't see anything that looked like bearing material so I think thats a good sign. There was a thicker viscosity fluid in the pan at the bottom though, silver in color. I'm hoping that is some sort of assembly lube. Any ideas?
      I think bearing material would show up as babbit between the filter folds. I don't know what the silver stuff would be, maybe assembly lube, zinc additive, some minor normal break-in stuff.
      Sounds okay
      May 2002
      Northern California
      I'm wondering if there is to much crank case pressure. Thinking about plumbing 1/2" lines into back of valve covers and tying into collector.
      eeek i hope not. If they used cork on the intake fronts then i'd say no.
      Reminds me of the time a guy used full synthetic to break in the motor and the rings failed to seat. I assume your builder was smart enough not to make that mistake.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2009
      El Dorado Hills
      Vince
      I dont think anybody uses gaskets in front of the intake anymore. I never have. Typically a thick bead of Permatex. I think he's probably a good builder, just buried in work. Took him 6 weeks to get motor to me and started it in the 5th week. We set a schedule for me to come and watch dyno pull and I think he rushed some of it.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      May 2002
      Northern California
      damn. are you absolutly sure its the oil pan? Could it be up higher? Hope you get it sorted out.
      Vince
      Fontana, CA
      That sounds like a bunch of crap. Time for the builder to pay to have a local shop fix it for you.
      also, are your tires on backwards?
      Nick R.
      Dec 2009
      El Dorado Hills
      Good catch on the tires, I new I had to swap them around just hadn,t gotten to it yet.
      Gaetano Cosentino
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by 6'9"Witha69 View Post
      Builder is on east coast time which makes it hard for me to contact him while I am working. Tried to call todayat 3:00 p.m my time and no answer so left e-mail. Basically told him he needs to make this right again.
      After I replaced oil pan gasket it no longer leaked so when I first start it no leaks like before. When I get back from driving it I get about 3 ounces of oil on the floor. May not sound like a lot but I think it is. I just wonder how much I lose total while driving.
      Hopefully this guy acts in good faith. If it was me I would. What is right is right or he could chalk it up to bad Karma.
      Gaetano Cosentino
      Henderson,NV
      That's way to much. You'll burn up your clutch quick. I wouldn't want anymore than a pinky nail. Maybe you should just tear it out and have it gone through by another builder. Sure seems like a real hack job. I've got a great engine builder in Hesperia. Jason Pettis
      Todd
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by Vegas69 View Post
      I thought about the clutch but I'd hate to miss Buttonwillow. Man this is killing me.
      Right now I'm thinking I am going to chance it. If I could make Buttonwillow and the Spectre341Challenge thats all I ask.
      I still haven't even fully opened up the secondaries yet and she feels pretty strong. Got rid of the torque bounce in the rear by adjusting shocks. Took her around a couple of loop freeway entrances and there might be a slight push.
      Was in fear of getting ticket so I didn't push to hard but right now handling feels better than decent.
      Gaetano Cosentino
      Aug 2001
      Connecticut
      Any chance that you are getting excess blow-by or crankcase pressure pushing the oil out? (check your breathers?) Just a thought, sometimes these oil leaks are not necessarily the gaskets fault but a sign of something else.
      Or could it be higher up since it sounds like your pan seal was re-done... crank seal, one of the 3 plugs at the back of the cam, rear of the intake, etc?
      I had a pan leak turn out to be a weld-in bung for the oil heater. It doesn't take much to make a huge mess.
      -Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Quote Originally Posted by 68sixspeed View Post
      -Dan
      Hang in there Cos. I understand why you are not happy -and justifiably so- but look at the big picture as well. It sounds like the motor runs really strong and that is the most important thing. I agree with Dan that it could be a bunch of little things that are making up the oil spot now that you fixed the pan gasket. BTW almost all 2 pc main SBC seals leak some, and this is the reason they went to the 1 pc type. Go to Buttonwillow and have a great time. Those little Alfa's are going to say what the hell was that as you motor by them at warp speed on the track. I can't wait to see the video!!!
      Regards
      CurtiSS 69
      Dec 2009
      El Dorado Hills
      -Dan
      I checked everything and it is definitely the rear seal. I thought about excessive crankcase pressure but ruled it out after fixing intake and pan gaskets.
      Gaetano Cosentino
      Dec 2009
      El Dorado Hills
      Took car out again after work today. Fully opened up the secondaries for the first time.
      I normally take a short drive down Green valley Rd, pull in at the parking lot of the Purple Place(yocal hangout), drive through parking lot and see a bunch of Harley's and a red 64 pro-touring vet. I slowly drive by idling(rumpeta, rumpeta,rumpeta) as they stare at me from the outside tables. Then I get to the edge of the parking lot pointed back up Green Valley Rd, slowly pull out and then stomped on it, LMAO. HOLY $#it !! Broke tires loose up to about 6 grand then hit second and rear squatted and pulled.
      Reminded me of when I used to pull outta the parking lot after high school got out almost 30 years ago, LOL.
      Gaetano Cosentino
      Rustburg, Virginia
      LOL, Yup I can still hear the principal yelling at me......we had to turn left, uphill to get out of our parking lot....so the burnout ended being a very long one.
      Hows the oil situation?
      May 2009
      Sounds like a fun little burnout. It's very cool what you can do with the old school big blocks, a little aluminum, the new technology and abundance of modern parts.
      Was it staying straight down the road?
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by John Wright View Post
      Just got back from Buttonwillow a day and a half early. Oil leaks worse now and motor definitely needs to come out.
      Gaetano Cosentino
      Greenwood, SC
      I'm still waiting on this so called 1st to 2nd burnout video.... lol.
      I like your build style..... Need something..... go freaking get it!
      Hope your luck changes!
      JC Scott
      May 2009
      Yeah... hoping for good luck, for you
      Sounds like a rear main seal though.
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by cheapthrillz View Post
      Right on, I'm glad you didn't forget!! Just feeling motor out before I tear into her. I haven't even fully opened up the secondaries yet.
      But trust me, I'll slam second without even lifting my foot, LOL.
      Thanks for all the support guy's. You are solid people. Hope to see you at an event some time.
      Gaetano Cosentino
      Jun 2009
      Piqua, Oh
      Do you have any wheel hop? I have the first stage Global West leaf springs, and was really hoping not to have to use traction bars. (hate the way they look)
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
