    Page 9 of 48 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 19 ... LastLast
    Results 161 to 180 of 954
    1. #161
      Illinois
      Very cool ride man. I just went through all your posts to see what all you have done, impressive. I like how you're doing a G-Body and showing the potential of these cars, very nice.
      1989 Camaro RS Flashback
      Corey
    2. #162
      Woodbine, MD
      Video on my broken rear....
      We went in and took it all apart and nothing seemed bad or broken. There was some cone/clutch material in the fluid though. We put it all back together with new pinion bearings and will use thicker 75-140 gear oil and see what happends.
      Douglas Lutes
      1988 Monte Carlo SS
    3. #163
      May 2011
      socal
      ur car is so bad ass doug sorry about the rear end.
      hpjunky danny
      1969 camaro project wayne due c4 subframe
      2004 scsb silverado jgpclone forged 370 lq9 tt gt3071 built 4l60e trans 4:10 gears daly driver
    4. #164
      Woodstock, Ga
      Isn't that show a re-run? lol
      Did you check the bearings out at the wheel end of the axle? Might just need to be snugged back up?
      Robert
    5. #165
      Woodbine, MD
      Quote Originally Posted by RS_Customs View Post
      Robert
      they were ok...
      Douglas Lutes
      1988 Monte Carlo SS
    6. #166
      Woodbine, MD
      Tonight I found this out......
      Seems like something hit the adjuster and broke it off. The other shock still has the adjuster on it..but it is all bent too. What could have hit this adjuster?? It sits in the front lower control arm spring cup.......no idea.
      Douglas Lutes
      1988 Monte Carlo SS
    7. #167
      Woodbine, MD
      Put the pro-touring.com stickers on today......came out ok I think.
      Douglas Lutes
      1988 Monte Carlo SS
    8. #168
      Phoenix,AZ
      Looks really good on car.
      James W.
      1987 Oldsmobile
    9. #169
      Florida
      PT sticker looks cool Doug!
    10. #170
      Woodbine, MD
      This is the second Inline Tube brass prop valve I have installed...the first one leaked out of that lil front valve/button thingy.
      New Aluminum Master Cylinder...my old one started leaking randomly as soon as I replaced that prop valve!!
      Douglas Lutes
      1988 Monte Carlo SS
    11. #171
      Woodbine, MD
      Now I am going to do a lil write up on the install of the GNS Performance Fender Brace kit for a G-Body
      Here is the kit all layed out and tools at the ready. All you need is a 7/32 allen wrench and a 9/16 wrench. I did put some anti-seize on the hardware since they are all stainless steel.
      Contact info...had to give the company free plug!!
      Douglas Lutes
      1988 Monte Carlo SS
    12. #172
      Woodbine, MD
      First step was to find out where the fender mounting brackets were going to go. These were meant to bolt onto the third fender bolt on a Grand National Fender. A Monte Carlo SS doesn't have this bolt so a hole had to be drilled. I assembled the braces and found where the hole will be placed. After center punching and drilling the hole this was the result.
      I found some black hardware in my shop and bolted the "L" bracket to the inside of the fender. I used a nylon lock nut.
      I was curious as to how my Harwood Cowl hood would fit with these fender braces intalled so I checked the hood clearance with some putty. The hood has no clearance issues!!
      Douglas Lutes
      1988 Monte Carlo SS
    13. #173
      Woodbine, MD
      Here is the drivers side brace all mounted up.
      Douglas Lutes
      1988 Monte Carlo SS
    14. #174
      Woodbine, MD
      The passenger side brace installs the same way as the drivers side!! Find the correct position for the fender brace mounting bracket, drill the hole and install it. It's that easy!! GNS Performance does include a direction sheet in the package that explains how much tension each brace needs..
      These fender braces install easy, are a quality product, and look killer under the hood!! I drove the car with these installed over 300 miles this weekend and they did not come loose and performed perfectly!!
      Douglas Lutes
      1988 Monte Carlo SS
    15. #175
      The Netherlands
      Country Flag: Netherlands
      looks good... always nice to do these small improvement jobs
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    16. #176
      Charlotte
      Hey Doug - just noticed you have a lift... you suck!
      LOL - jk.
      That rear end sounds terrible - lol!
      Looking forward to your updates.
      2014 Chevy SS LS3 / 4 Door
    17. #177
      Aug 2009
      chicago
      Your monte is sick bro!
      86 regal ltd.More to come.
    18. #178
      Woodbine, MD
      Quote Originally Posted by uneek1976 View Post
      Thanks man!!
      I really appreciate all the feedback guys!!
      Douglas Lutes
      1988 Monte Carlo SS
    19. #179
      Woodbine, MD
      Couple pics form the Fall 2011 "Endless Summer" Cruising weekend in Ocean City, Maryland
      On saturday at the the Hooters...huge hang out down there.
      My g/f Kim's 04 Cobra and my car...don't worry...her car will be at events next year!!
      Douglas Lutes
      1988 Monte Carlo SS
    20. #180
      Woodbine, MD
      Douglas Lutes
      1988 Monte Carlo SS
