    Page 7 of 48 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 17 ... LastLast
    Results 121 to 140 of 954
    1. #121
      Feb 2010
      Central NJ
      This car totally Sucks!
      hahhaha, just kidding Doug, I'm just jealous of your wheels!!!
      We have to meet up this summer for a cruise!
      -Sean
    2. #122
      Woodbine, MD
      Thanks for all the kind words guys!!!!!
      Sean...yes we do!
      Douglas Lutes
      1988 Monte Carlo SS
    3. #123
      Dec 2008
      Lehigh Valley Pa
      Great to hear the engine is alright. I still think we should plan a meet up at the GM Nationals in Carlisle.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
    4. #124
      Oct 2008
      Kingsland, GA
      I'm jelly
    5. #125
      Woodbine, MD
      Quote Originally Posted by The Stickman View Post
      I agree 100%. We need to get sean up there too.
      Douglas Lutes
      1988 Monte Carlo SS
    6. #126
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by SicMonte View Post
      How's this?
      https://www.pro-touring.com/showthre...718#post797718
    7. #127
      Woodbine, MD
      perfect
      Douglas Lutes
      1988 Monte Carlo SS
    8. #128
      Woodbine, MD
      UPDATE:
      After RTTS I had a lot of noise in the front brakes when I applied pressure to the pedal. It was a very high pitched squeal. Here is what I found. This will also serve as a "how to" on replacing brake pads on the new Baer T4 calipers.
      Here are the brakes...
      Before even starting the job I thought of where the capiler was gonna rest while it was unbolted. The upper A arm is perfect for this, just make sure you cover it so the nice new caliper doesn't get scrathed.
      These are the caliper bolts. A 10mm allen socket fits them.
      Caliper is off and resting on the padded upper A arm
      The caliper bolts came with locktite on them from the factory, be sure to use more when installing the calipers again.
      Douglas Lutes
      1988 Monte Carlo SS
    9. #129
      Woodbine, MD
      Looks like the pistons were digging into the backing material on the pads. This could be a major cause of the squealing. I added some grease to where the pistons contact the pads to help with the problem. **Note: Both sides had this issue.
      I also noticed that the pads and rotors were glazed. I took some emory cloth and sanded off the glaze on the pads. You can notice a difference beween the two pads. The glaze occured because I did not properly bed my pads before I took it out onto the track.
      Here are the glazed rotors.
      To de-glaze the rotors I simply scuffed them down with a scotchbrite roloc disk on an air angle grinder. Glaze came off no problem.
      Douglas Lutes
      1988 Monte Carlo SS
    10. #130
      Woodbine, MD
      Here are some shots of the Baer hubs with the ARP wheel studs. The caliper brackets are no joke!!
      Here is a look at the inside of the T4 caliper. You can see the four pistons very well.
      When I went to put the pads back into the caliper I greased the slots where the "ears" of the pads go into the caliper. There is a small metal bracket that sits in there that holds the brake pads just like every OEM caliper. I put some grease where the pads hit that metal bracket and there is now more squealing!!
      Douglas Lutes
      1988 Monte Carlo SS
    11. #131
      Dec 2008
      Lehigh Valley Pa
      Those brakes sure do look nice.
    12. #132
      Woodbine, MD
      why Thank you sir!!
      Douglas Lutes
      1988 Monte Carlo SS
    13. #133
      Jun 2009
      Central FL
      Nice build. Lots of good stuff. Really like the brakes.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
    14. #134
      *drool*
      Jul 2010
      Monticello, MN
      Hey, ya gotta check this out.
      "I had to do it."
    16. #136
      Woodbine, MD
      Quote Originally Posted by Roberts68 View Post
      "I had to do it."
      ok you got me.....good one!!!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    17. #137
      Jul 2010
      Monticello, MN
      I thought you might get a kick out of that!
      It is a sweet build thread,
      Mine is more in the mostly stock car with a nice stack of boxes accumulated relatively nearby stage.
    18. #138
      Apr 2011
      Tennessee
      Brakes
      Very nice brakes. I can't wait to get my other rotors and rear brake set up too.
    19. #139
      Oct 2009
      Garland, Tx
      Awesome build thread sir!
    20. #140
      The Netherlands
      Country Flag: Netherlands
      I stumbled upon this build thread by accident.... I like what you did to the Monte.
      Martin
      www.pro-touring.nl
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
