    Results 1 to 3 of 3
      Crown Point, Indiana
      which way does it flow?
      This may be a dumb question but here it goes! LOL
      Trying to flush the block and radiator which way does the water flow in a car engine?
      My thought was water gets pushed out of the bottom of the water pump into the lower rad hose to the rad passes through the tubes is cooled off then back into the block from the top rad hose and repeat does this sound right?
      Nov 2009
      Peoria, Az
      Opposite.
      Thank you. I just realized this when I was hit with a nice stream of water from the thermostat housing as I turned the water pump on
