    Page 7 of 10 FirstFirst ... 2 3 4 5 6 7 8 9 10 LastLast
    Results 121 to 140 of 182
    1. #121
      Port Richey Fl
      Brian has to make or patch the inner structure since it is not available.
      Next epoxy before making another patch
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
    2. #122
      Apr 2011
      Miami, FL
      A lot of hard work going into that car. Its coming along great.
    3. #123
      Jun 2011
      Amazing fabrication.. two thumbs up!! good to see such an awesome car being saved from the scrapyard.
      Dave Van Nuys
      83 455 Regal in progress
    4. #124
      Port Richey Fl
      Since you cannot get this Brian had to patch the original
      Rusty Gillis
    5. #125
      Port Richey Fl
      Brian is replacing part of the left outer rocker
      This is what was inside
      He also cut a hole in the front so it could be cleaned out and epoxy primed
      Rusty Gillis
    6. #126
      Oct 2011
      Katy, Tx
      Great progress...
    7. #127
      Port Richey Fl
      Brian replaced the left rocker
      Starting to repair the left quarter panel inner structure
      Rusty Gillis
    8. #128
      Does he prime (weld thru primer ?) the inside surfaces of the metal before welding ? Is any other rust prep done other than to paint with a primer ? As a home builder I usually just rattle can primer on bare metal, and need to start trying some weld thru primer for spaces that I can't reach. Just wondering how the pros do it differently.
    9. #129
      Nov 2010
      sweet home alabama
      Man that work is superb
      63 Fairlane 500
      07 Mustang GT Convt
      https://www.pro-touring.com/showthre...Bring-the-rain
    10. #130
      Port Richey Fl
      Quote Originally Posted by preston View Post
      We use SPI epoxy primer
      Rusty Gillis
    11. #131
      Port Richey Fl
      More rust repair
      Rusty Gillis
    12. #132
      Feb 2010
      Plainfield, IN
      Is there going to be any original metal left on the car?
      1969 1/2 Maverick
      4.6 DOHC, Mustang II front, T56, & Cobra IRS
      Custom Interior in the works.
      http://www.cardomain.com/ride/2200206
    13. #133
      Orlando, Fl
      The trans tunnel was good :P I will say this, when Chris first picked up the car, it didn't look that bad... I began to wonder when we were ripping the window trim off. I think I have a new nickname for the poor thing, Skeletor. Or Robostang maybe. :-)
      Nick DiPrenda
    14. #134
      Port Richey Fl
      Test fitting the sheetmetal before welding in the rear package tray panel
      Rear panel is welded
      Marking the area that needs to be cut out for the Graverobber wheel wells
      Rusty Gillis
    15. #135
      Orlando, Fl
      Looks great Rusty, can't wait to see all of the tail welded in.
      Nick DiPrenda
    16. #136
      Aug 2008
      Getting really excited about the car. She will be a nice clean shell soon (with a few tweeks). Great work Rusty and Brian.
      ATO: Not a ton of the original car is left. Trans tunnel, firewall, front clip, trunk and backseat floor, frame rails. I think they can salvage the roof skin.
    17. #137
      May 2002
      Northern California
      rusty? Graverobber wheel wells? is that a descrition or a brand. LOL
      great job, metal work galore.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    18. #138
      Port Richey Fl
      Goodmark makes them for Graverobber.
      Rusty Gillis
    19. #139
      Port Richey Fl
      The frame rail was notched and epoxy primed inside
      Patch welded in place
      Ready to install the right inner tub
      Tack welded in place
      Rusty Gillis
    20. #140
      Port Richey Fl
      The outer wheelhouse did not match the inner. We had this same problem on the 65 coupe and the outer wheelhouse was from a different vendor. Brian cut it in two than test fit the front
      He cut the rear section than welded it together
      After taking the B pillar apart we found it was beyond repair.
      They only make them for a coupe so he had to make a patch
      Rusty Gillis
