      Feb 2010
      maine
      TCI torque arm rear suspension?
      I posted a thread yesterday about rear four links and which to go with . Thanks for the responses. I have decided to go with total cost involved and there torque arm rear suspension. My question now is , If I decide not to buy this system with there rearend already welded in how hard would it be to weld my rearend to their unit. Im not sure what i would have to know. Obviosly side to side measurements and pinion angle but is there any thing else i would have to make sure of before i weld it in? Am i better off using there housing instead of the one i already have? I really do not want to buy their rearend. Some help would be great.. Thanks
      Nov 2009
      Davenport, Wa
      If you want to use your rearend it must be a 9" Ford. They supply the Torque-arm kit with a couple of fixtures that bolt to the third member studs. They positively locate the weld-on mounting tabs for the torque-arm. The instructions tell you exactly how far apart the axle brackets are to be welded and at what angle to set the pionion.
      Tim
      Tim Stromberger
      Tim's Hot Rods
      Dealer for TCI and Heidts
      Jun 2009
      So you already have a 9"?
      Feb 2010
      maine
      yeah i already have a 9 " rearend so i really don't want to buy another housing if its not real difficult to weld it in to tci's unit.
