    Results 1 to 9 of 9
      Westminster, MD
      KRC serpentine system
      Any one running this setup or using any of this company's parts? http://cgi.ebay.com/ebaymotors/SBC-S...Q5fAccessories
      Not familiar w/ the company but the set up looks pretty nice. Not sure the advantages/disadvantages vs. a regular March or GM system. Company website is www.krcpower.com
      Ed Cooney
      '96 Buick Roadmaster Estate Wagon, LT1/4L60, full bolt-ons & Solomon's tune, 18" Ridler wheels, lowered with Belltech springs
      ‘70 Buick Skylark Convertible project w/ GN drivetrain
      '91 Formula, pending track day build
      that's not a serpentine system- i don't see a belt that "snakes" around all the accessories- it's just a regular system that uses flat grooved belts instead of v belts.
      I have that setup and I really like it. Keeps the pulleys and belts in tight and helps to clean things up. You don't want a 30% underdrive though, you need a 1/1 system which that guy doesn't carry. Take a look at speedway motors fo the 1/1 kit. It is a nice set
      1968 Camaro Crossram EFI 385, TKO 600 fully REMed. 594 hp/576 tq-ft. ATX spindles, Speedtech control arms, Chassis Works G-Link on 12 bolt with REMed gears, Chassis Works mini tubs, 245/40-17 front, 335/35-17 rear.
      Oct 2005
      New Washington, IN
      I talked to the guys at KRC about their kits, and they said as of right now, they do not offer a pulley arangement that would allow the alt to function properly on a street car, but are working on it now.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Westminster, MD
      Thanks for the info, looks cool but obviously won't suit my needs.
      Ed Cooney
      Quote Originally Posted by Johnny Blaze View Post
      That's odd considering mine charges just fine! Since the alternator pulley is slightly smaller than the other pulleys, which I believe are all the same size, is actually overdriven slightly which does help with low speed charging. Since this motor peaks power at 6,500 I don't forsee over spining the alternator.
      Oct 2005
      New Washington, IN
      Maybe they are just being conservitive in their guide lines. I think i still have the email, let me check
      Oct 2005
      New Washington, IN
      quote".However on the street you will be lacking the sufficient alternator speed to drive it around town.Road racing only requires 1:1 ratios to run the alt,2:1 for drag racing but 3:1 for street use.At this point with some pulley changes to the kits below at best we could get 2:1.Street alternators for example need 2400 rpms to charge at 600 rpm idle.We will have some smaller Delco alternator pulleys in the near future that will get closer to the 3:1 ratio"
      Dec 2009
      I had a similar problem. Just went to the Internet and found someone to help out. I used the boys at Concept One Pulleys when I had the need for a custom setup. You can find them online, like I did, by visiting the link below:
      Car pulley systems
      -Robertson
