    Thread: Autocad anyone?
      Jun 2005
      Autocad anyone?
      Shot in the dark here, but we have some bright people on this board. If anyone uses Autocad, I have a question.. I'm using 2009. I'm taking a beginning autocad class and I've learned enough that we're starting to dimension whole floors of buildings. Everything I know so far is in 2D though...
      I need to layout a cyclone for a friend, and he gave me all the dimensions and I need to put it into an autocad drawing (Dwg). The bottom cone part is what he needs, and I have no problem laying it out in autocad, except that the dimensions call for an angle of 71.70 degrees.
      For some reason when I use the line command and enter @45<71.70 it draws the line, but when I go to dimension it, it reads 72 degrees.
      He wants exact tolerances on the drawing. He plans to take it somewhere and have them plot it. Does anyone know how I can change that? I went under the units menu and changed the angle dimensions to 0.0000 tolerance, but it doesn't seem to make a difference, even if I change it to degrees/minutes/seconds.
      I'm not sure if the problem is in the actual line's tolerance or if the problem is in the tolerances used for dimensioning, or where to fix it?
      I normally use the distance inquiry command to double check my line lengths, but I don't know how to do that to check the degrees of an angle.
      Anyone that can field this one?
      Mathius
      Nov 2007
      Germany KMC
      It's been 10 years since I was a pro at this but, I'll give it a stab.
      You need to change the basic setting for the drawing not the dimension tolerance, it seams as if it is set to round up.
      I wish I could give you more but I have not even played with it in about 3 years.
      Good luck.
      Adam
      69 Chevelle SS 396 < --Sold
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      San Rafael
      Dimension
      I'd go into dimension style manager and check the angle tolerances.
      These examples may help a little....
      http://www.we-r-here.com/cad/tutorials/level_4/4-11.htm
      http://www.jlab.org/accel/eecad/acad/advanced_dimen.pdf
      Paul
      Jun 2005
      Quote Originally Posted by smhigh View Post
      That did it. Thanks. Apparently it was just the dimensions and the actual line arc must have been ok. Drawing done. Thanks.
      Mathius
