Thread: Tig conversion kit?
03-08-2010 #1
Tig conversion kit?
I have a lincoln 200 arc welder, can i get a tig conversion kit for it? I understand it will probably be a scratch start, but i would like to do 1/4 to 3/8 aluminum. Also some mild stainless would be nice.
1969 Chevelle, 33458 original miles. 5.3L injected soon to be awesome!. 4 wheel disc brakes. Built to cruise.
An artist is never ahead of his time. He is his time. The others are just behind the times.
03-09-2010 #2They sell tig torches that you can clamp a stinger handle on, attach a gas hose, etc. and weld with. Mild and stainless steels aren't a problem, make sure your torch is - and the ground is +. The question is "Does the machine weld AC? If not, you can forget about welding aluminum.
The needs of the many outweigh the needs of the few.
03-09-2010 #3
Full Blown G-Machiner
- Aug 2004
- Boston MA
- 686
Pretty much isn't going to work. With out HF and AC balance control, you're not going to be able to weld AL.
1967 #s RS
03-12-2010 #4
- Jun 2005
- 543
If he's talking about those little 220amp buzz boxes that are sold at home depot, lowes, etc. they're ac only to begin with. You can grab them on craigslist for about $100 regularly used.
But can't you weld aluminum with DC+ ? I thought I had heard that, but I've never tried to tig aluminum with anything besides ac and I haven't done that in about 4 years, so I can't confirm it.
Then again, if memory serves, high frequency is what starts the arc prior to touching the material if you're not using a foot pedal and I don't know how you could scratch start aluminum? It's too susceptible to contamination. The tungsten burns at a much higher temperature than aluminum and contaminates the weld from the word "go."
Mathius
03-12-2010 #5
