Results 1 to 13 of 13
Thread: HELP pinion angle
- May 2009
- Minnesota
- 615
HELP pinion angle
1968 Firebird 400-400 combo
solid GW body mounts at stock heigth, not wedged.
Stock subframe
stock motor mounts and tranny mount
QA1 coil over front suspension
The front sub frame,motor,and tranny should be close to what came from the factory for ride heigth.
The rear has a leaf spring suspension with I think a 1 1/2" drop spring.
The floor in my garage is not level and I do not have a spot that is level as of right now. Still snow in the driveway. LOL
The car is not completely loaded. But I have tried applying several hundred pounds to the rear of the car and the pinion angle does not change. The body of the car just seems to sink down.
I had to weld on new perches to the rearend. I used a 1973 nova rearend as a reference point for mounting the perches and spot welding them on.
I installed the driveshaft last night and here is what I have for measurements.
I put a angle finder on the driveshaft right in front of the rear pinion. I have 3 degrees angling down to the floor.
Next I put the u joint that is bolted into the rear pinion so it was pointing straight down. I put a socket and my angle finder on the cap of the u-joint. I came up with a 5-5 1/2 negative degrees (pinion is angling down to the floor) Does this sound close enough for me to weld the perches up solid? If I have to I can always add a shim if needed.
Just wanted to make sure that I am not way off.
Thanks in advance for any help.
03-05-2010 #2
- Jun 2009
- 206
If both are pointing downward basically creating a "V", one angle is 3 degrees and the other 5-1/2 then you actually have 8-1/2 degrees of u-joint angle which is excessive. You could shim it later but I would correct it now before you fully weld the perches on. Typically a u-joint does not like to see much more than 4 degrees. I would knock those tacks loose and shoot for somewhere around 2-3 degrees of combined angle.
03-05-2010 #3
- May 2009
- Minnesota
- 615
03-05-2010 #4
