      Jun 2008
      Southaven, MS
      '69 Camaro Suspension Bushings
      I'm collecting all the parts to rebuild the front end on my '69. Its still got the original non-power drums and steering. The bushings are also shot. I've got a steering box out of a '87 T/A, Hotchkis 2" coil springs, and a front disc brake conversion kit. Which bushings should I use. I'm looking at PST Poly-graphite or urethane. Its just going to be a cruiser with the family.
      1969 Black Camaro,matching numbers 327, 3-spd manual. 17" Foose Wheels-'71 Chevy C-10, 79,000 original miles, Lowered 5&5. '86 Dodge Ram50, Lowered, Convertible waiting on a LS conversion. Also bought a '69 Blue Camaro RS SS clone, 350, auto, Lemans Blue, Comfortweave interior.
      Dec 2009
      Austin, TX
      PST polygraphite bushings are great for the price if you are using stock upper and lower A-arms - I've used them on my 69 Camaro and 70 Chevelle with great results in the past. It comes down to budget vs your goal. Since you are just building a cruiser - good replacement parts are a must, and ride quality is an issue as well. If you go that route you will not be disappointed.
      Nick Visciani
      1969 Camaro 454 Richmond Super T10, SpeedTech Pro Tour suspension, AFX Spindles, Kore3 C5 325MM Brake Kit, 10 Bolt 355 Posi, Tran AM rear Discs
      2002 C5 Corvette -
      It begins - [url]http://www.brokenboltgarage.net
      Fontana, CA
      If you go PST or other Poly bushing, grease the snot out of them during assembly, and make sure everything is tigtened with full vehicle weight on the suspension. Also, use the Energy suspension sway bar mounts, as they are greasable. Last I checked the PSTs were not. Trust me, a lot of additional stiffness and binding can come from this place alone.
      Nick R.
      Dec 2009
      Austin, TX
      Agreed with 6'9"Witha69 just replaced the worn out ADDCO stuff for Energy sway bar mounts for the very same reason! Good catch
      Nick Visciani
      2002 C5 Corvette -
      Jun 2008
      Southaven, MS
      Thanks for the information. Hopefully I'll get off my butt and try to order the bushings this week. I'm going to talk to my sons girlfriends mom that works at a parts house to get some Moog ball joints and other suspension stuff. I want to get the suspension done so I can cruise safely for a while.
      Feb 2007
      Awesome, needed this info myself.
      Chicago suburbs
      Go with stock rubber or delrin- I'm sure I'll get some crap for this, but poly bushings and subframe mounts are a waste of money- really a poor design if you look at them. Not really a bearing, not really a bushing, and if there are no zerks, then I hope you don't mind squeaks. Worst mod I ever did. And yeah I used all the grease they provided with the kit. 2000 miles later I have a squeaky, binding, mess. Rubber would be fine for a cruiser- most any oem bushing is rubber.
