    Results 1 to 20 of 23
    Thread: New AMC guy
      Sep 2009
      Ontario, Canada
      New AMC guy
      New guy from Ontario, Canada. Noticed a few AMCs on here, so adding another. My user name is AMC Racer, but just getting started so more of a wanna-be-racer than a real one, but good to have plans. Hoping to update my car with better brakes, tires, suspension, gearbox, etc. to get all-around performance and this forum seems like a good place for ideas.
      Like most guys, started with engine upgrades first, now need to get the drivetrain and chassis up to par. Here's a small picture of my '74 Javelin AMX from a couple years ago. Currently has a 401 with Indy heads, small street roller cam, mild suspension upgrades, etc.
      Hope I can learn lots and help others if I can.
      Cheers!
      Duane
      montreal CANADA
      nice Javelin, i got a friend with a 74 SST and hes swaping a 06 Viper chassis and running gear in it cus finding aftermarket parts is very hard to find, but thay are out there.
      my friends car: http://www.cardomain.com/ride/563405
      here, you might be interested in this. good luck
      http://www.classicone.com/wsc/catalog/amc/amc_per1.htm
      Wayne S
      79 Pontiac Trans Am WS6
      krepower.com Aluminum MR-1A Pontiac 505cid
      04 Ram SRT-10 Viper spec Tremec T-56
      no idea for suspension yet....
      Year One billet snow flakes soon
      SpitzKraft HID conversion kit
      http://protouring79ta.monchar.com/
      El Cerrito, CA
      Welcome! great car, the best actually. and no, I'm not biased. it's just a fact
      PT_79_TA_461 tell us more about the jav with viper bits
      -Asif- Penngrove, CA (SF bay area) asifnyc.com - AMC blog
      1974 Javelin NASA American Iron road race car
      1975 AMC Matador road race project
      1973 AMC Javelin/AMX driver
      1975 AMC Gremlin driver
      1975 AMC Gremlin track rat project
      Jan 2010
      Ontario, Canada
      Welcome aboard, this is a great site for getting ideas for your car, however very little AMC.
      What part of Ontario are you in?
      Derek
      welcome aboard! nice car!
      Sep 2009
      Ontario, Canada
      Thanks guys!
      That yellow '73 and yellow Spirit are a couple cool AMCs! Tons of nice cars on here from all makes with lots of ingenuity. Hope mine can be as nice someday.
      I'm near Brantford.
      Duane
      Dec 2008
      Lehigh Valley Pa
      Welcome to the forum. Keep us updated on the progress of that AMC.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      iceland
      Country Flag: Iceland
      Aug 2008
      I like the look that you have right now! It sort of has that Trans-Am feel to it, which is what I am going for my build. It looks stout and aggresive. May I ask what your wheel/tire/size combo is and also what suspension upgrades you did? Thanks!
      C. Marcus
      1974 AMC Javelin
      1973 Chevrolet El Camino SS
      Sep 2009
      Ontario, Canada
      Thanks guys!
      Nice to see another Javelin! Mine has 15"x10"x5"bs rear, 15"x8"x4"bs front "D"-slot stock car wheels modified to mount stock AMC centre caps. The tires are old Firestone Firehawk 295x50 rear and 235x60 front, so just a basic tire ... but what I could afford at the time. Fitted a 1 1/16" front bar and 3/4" rear bar, KYB shocks, urethane bushings, AGR 12:1 box and pump. The side-exit pipes were cool and sounded nasty, but exhaust would come into the cabin with windows down, so now has 3" X-pipe and 3" tailpipes (modified Mustang kit). The rear spoiler and cowl hood are stock, with custom front chin spoiler. Otherwise, more or less stock.
      Duane
      '74 AMC Javelin AMX
      Iceland
      Aug 2008
      Was there something specifc you did to achieve your lowering with the KYB shocks? I know you can get a full coilover kit for the fronts now, I am just wondering what to do for the rear. I am trying to keep mine "low-dollar".
      C. Marcus
      1974 AMC Javelin
      Sep 2009
      Ontario, Canada
      It hasn't been lowered yet ... just 35 yr. old springs and the wider tires fill up the wheel wells . To lower the rear, just use lowering blocks between spring and axle. Check the AMC forums for info. on lowering plates for front spindles (offset holes for the bolt-on AMC spindle). The lowering plates are "low-dollar" compared to the coil over kit. The KYB shocks are same as Mustang front and Camaro rear. I think some guys have changed the front coil lower seat to one from an early Mustang so they can use common Mustang springs. Not much readily available for AMC, so need to be resourceful. Hope this helps.
      http://amccars.net/cgi/yabb2/YaBB.pl?num=1266243193
      http://amccars.net/cgi/yabb2/YaBB.pl?num=1266243593
      Duane
      '74 AMC Javelin AMX
      El Cerrito, CA
      here's a pic of my car with 2" lowering blocks on the rear. front has the WSC coil over kit...
      Aug 2008
      Asif - where did you getyour 2" lowering blocks?
      C. Marcus
      1974 AMC Javelin
      El Cerrito, CA
      lowering blocks
      you should be able to get them at your local parts strore (napa, kragen, o'reily, pep boys, auto zone, etc). if you have any trouble finding them you can just order from summit: http://www.summitracing.com/parts/DJM-LB2LK/?rtype=10
      Aug 2008
      Blocks + Handling
      Another question - and anyone here who has an answer cen let me know - from what I gathered from some other forums specifically an article I read from a "spring specialist" at Eaton Springs is that you want to stay away from blocks for the sake "axle wind-up and poor vehicle handling" Any thoughts??
      C. Marcus
      1974 AMC Javelin
      Sep 2009
      Ontario, Canada
      ... not many "low-buck" options ... maybe de-arched springs instead of lowering blocks ... but new springs to suit your desired ride height would be a better choice but more $$. I've not lowered mine yet 'cause too easy to crunch the headers. If you want high-tech, high-dollar, Control Freak Suspensions has just prototyped tubular front and 4-link rear suspension for '70 AMX. Front parts will fit your Javelin. Rear for later Javelin may need some changes. It's getting easier all the time to build an AMC ... if you have the cash. Hope this helps.
      Front: http://www.freakride.com/amc.html
      Rear: http://theamcforum.com/forum/tubular...863_page4.html
      Duane
      '74 AMC Javelin AMX
      Lawrenceburg, TN
      Welcome to PT
      all this AMC love is making me feel all Fuzzy ha ha ha
      Aug 2008
      Asif - do you have any issues with your car and handling when it comes to auto-x? I am trying to nail down if going with lowering blocks is the way I want to go. Thanks!
      C. Marcus
      1974 AMC Javelin
