    Results 1 to 20 of 26
      May 2009
      rear mount turbo
      Anyone put a universal rear mount turbo from sts on to a first gen camaro? If so can you please post pictures.
      Jun 2009
      Cape Coral, FL
      I've been interested in this as well, I've emailed STS twice, still waiting for a reply...
      Jul 2008
      Strasbourg, France
      Country Flag: France
      I never got a technical answer from STS, so I decided to build it myself.
      I used SS pipes and elbows:
      It should be finished in 2 or 3 months (I am switching to efi at the same time)
      I will post some newer pics with the turbo installed in the car this evening.
      Jul 2008
      Strasbourg, France
      installed in the car:
      I have to finish the intake pipe (3" SS also):
      UK London
      Nice!!!. This has to be the best car specific site on the net. so much info!!!!
      st. paul mn.
      how much boost are you going to run? what kind of power plant do you have?nice job on the build so far please post up more picts.as your build progresses.
      Feb 2007
      Tha' South
      Looks nice! You need to start making these kits for the older muscle cars.
      73 Camaro LQ9, BW S480 Turbo, Jake's STG 3 4L80E, E85.
      Jul 2008
      Strasbourg, France
      The engine is a 383 ,with a 200-4R trans.
      For the beginning, I will stay with low 7PSI boost.
      I will maybe increase it after upgrading the engine block and crank.
      Jul 2009
      How well do these sorts of setups work? First time I heard about them everyone was basically saying they would not work very well. I always was kind of interested in them though especially for a tight engine compartment.
      "I can drive any forking thing around"
      Build Log http://banditcutlass.wordpress.com/
      Tallahassee + Seminole, Florida
      It'll cost you about the same to build it yourself, using higher quality materials and parts. Just find a reliable exhaust shop and you're golden.
      I have an STS kit on my '05 GTO and it's ****.
      What kind of turbo is that? Looks pretty nice!
      Jul 2008
      Strasbourg, France
      That is what I was thinking.
      for the same price, I was able to choose all the components. STS never replied my mails about technical questions, to tell me which turbo would be sent with the kit.
      I contacted TD Autowerkes, they gave me advices on the turbocharger...
      the turbo is a precision 6765 journal bearing with billet compressor wheel.
      I noticed that compressor wheel. Looks nice my man!!
      What kind of power are you looking for? I like driving mine because it has nice and linear power delivery... nothing unexpected or violent.
      Although, I'd kill for a KB..... :/
      Jun 2008
      stupid question but would it be easier to make food power with this type of turbo setup on an efi car vs. A carb. What real world problem would one expect.
      May 2000
      Quote Originally Posted by rebelgtp View Post
      Basically, they work.
      I remember reading in my Fastest Streat Car magazine, where I believe one was running 6's with a rear mount set up.
      Feb 2002
      Springfield, MO
      I don't know about FOOD power.......but.....
      GOOD power, yes Efi will usually run a bit better than a carb. But only because of better tunability. Carbs work just fine tho I must say!
      Quote Originally Posted by vyking67 View Post
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Jul 2008
      Bethlehem PA
      Wow ! These pics raise so many questions for me.
      How will you handle oil feed and drain for the turbo ??
      And clean air intake to the turbo ??
      And will not turbo lag be measured in minutes ??
      Don't get me wrong, it is a Beautiful set-up, and I hope it works even Better than you want it to. But my experiences with different header (exhaust) lengths and intercoolers (intake lengths) with my Buick has shown that even small changes (when everything is right at the engine) can cause very noticable differences in lag.
      Hopefully someone can explain what I'm missing ? ?
      John at SC&C
      Savitske Classic and Custom
      NEW # 610-381-6100
      '87 Buick Regal Turbo T - Since New
      Lots of SC&C, Fays2 Watts Link
      Boze Pro Touring wheels,
      Baer 13" Pro+ & SS4+
      Shaved door handles
      Custom S/S Exhaust
      memphis
      That is a great looking set up
      Dave
      Oct 2007
      Wa
      Quote Originally Posted by MarkM66 View Post
      You may be talking about Paul Major's Z06, I believe he has gone 6.98@210.
      Bob
      Houston, Tx
      Do you have any worry with all that heat near the gas tank?
      Jul 2008
      Strasbourg, France
      The turbo will be insulated with exhaust wrap.
      Before, I had a single crossflow muffler between the rear axle and the tank: the surface to radiate heat to the tank was much bigger and close to the tank then the turbo, even if the temperature is higher. (the muffler was nearly touching the tank)
      I don't think it will be a problem. if the temperature of the fuel goes too high, I will add a screen to decrease radiation.
