    Page 2 of 30 FirstFirst 1 2 3 4 5 6 7 12 ... LastLast
    Results 21 to 40 of 586
    1. #21
      Portland Or.
      nice work you guys are making it look easy!
      68 Camaro under construction
      -Chris-
    2. #22
      Lawrenceburg, TN
      now that the motor and trans is in the car i had to find a shifter i like for this monster- the new hurst indy is short and very stiff with a very short throw
      and build up a new clutch linkage with heim joints for complete adjustment possibility and gussets on the z-bar to stiffen up the entire set up
    3. #23
      Feb 2006
      Idaho Falls, Id
      I can't believe you bought a 68 Camaro for $100, last time I saw one under a few grand was a totally rusted out one about 10 years ago a guy wanted $500 for
      Traven
    4. #24
      Lawrenceburg, TN
      Quote Originally Posted by T_Raven View Post
      It was complete luck a friend of mine has 2 cars and his buddy has a car and an old lady (a friend of a friend) ask him if he wanted to buy her old car for 100 dollars(her crack head son had taken it apart), but they both thought it was a joke and didn't even look at the car for a week, they were arguing about going out to the casino or go look at the car, I over heard them and asked what car, "some 100 dollar junker some old lady wants to sell" I told him if you don't want it i will take it, he said "fine man its yours" but were not helping you tow that crap, and now it was mine
    5. #25
      Feb 2006
      Idaho Falls, Id
      Quote Originally Posted by rusty68 View Post
      Nice, I bet your buddies are kicking themselves
      Traven
    6. #26
      Lawrenceburg, TN
      getting some headers on
      First i wrapped them with Thermo Tecs exhaust wrap, and spayed them with there High heat paint and Spectre wire lock exhaust bolts
      I cleaned up the rear end with new gaskets bearing, Axel seals and brake lines, for now (mock up) I will leave the rear drums till I get a rear disc kit together
    7. #27
      Lawrenceburg, TN
      Now I am ready to put on the Hotckis rear leafs....you have to drill out everything for the huge 5/8 U-bolts
      and while i was getting the rear together I found some sweet rims from a vette...these will look sweet
      and my front suspension is coming together nicely also Using The hotchkis front coils springs with KYB GR-2 shocks
      and the hotchkis Tie rod ends and sleeves to keep every thing stiff
      and added for the fun of it the rear hotchkis rear shock tower brace
      super simple new shock bolts
      now lay in trunk and bolt it in
    8. #28
      Lawrenceburg, TN
      I got the rear disc brakes finally
      Pull the pumpkin cover first
      rotate the diff to find the retainer bolt
      using a small (full circumference) brake bleeder wrench loosen
      remove the bolt and set in a safe place
      slowly remove the diff pin
      now fish out the C-clip Axel retainers
      and remove the axel
      perfect time to replace rear bearings and rear seals
      now remove the 4 bolts holding the rear drums in place
      add rear brake brackets and rotor
      add the caliper
      reroute brake line and add retainer
      add E-brake lines
      doesn't get any easier than that!!
    9. #29
      May 2002
      Northern California
      Quote Originally Posted by Nor-Cal Speed View Post
      Great project, nice to see everyone is willing to give a hand.
      Any new updates Rod?
      Also what is the source of the AL linkage threaded tubes?
      thanks, Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    10. #30
      Lawrenceburg, TN
      Update to my build thread
      over the last few months I have put my car back on the to do List!
      so carpet went in first carpet from Trim parts
      then the seat frames from Scat/ Pro car
      a rear aluminum diamond plate safety wall
      and sound deadened from Thermo tec
      here's the Fast controller located under the seat for the air/fuel gauge
      and then the seats from Scat/ Pro car
    11. #31
      Lawrenceburg, TN
      Heres the motor 1.0 That I built in my garage, valve seat went very wrong with it time to update
      pulled of the heads to install new ones!
      clean up the fire wall
      new heads from Patriot Racing
      Comp cam rockers
      Comp cams push rods
      putting it together
      In this picture I'm testing a new Distributor-less ignition I ran it a few auto cross events but it need some dialing of the computer
    12. #32
      May 2009
      coming along nicely, what cam is in the engine?
      Curious, as I might want to match the cam to the heads/rocker system that you upgraded to.
    13. #33
      Aug 2008
      Quick question why did u remove the carb and switch to a different one?
    14. #34
      Lawrenceburg, TN
      Quote Originally Posted by 96t/acj View Post
      I had the demon Jr 500 and I couldn't get that thing to stop running rich, I rejetted it many times and still ran rich and sputtered, switched to a edelbrook 650, also tried a 750 edelbrook and the airflow meter ran close to optimal with the 650 with a mild rejett
    15. #35
      Lawrenceburg, TN
      now that the heads are done the owner of Gotelli's Speed Shop (Teddy) swung me a sweet deal on an aluminum radiator from BeCool so out with the old and in with the new
      I shot the new one with radiator black from eastwood
      the old radiator weighs nearly 30 pounds the new one is just 13 pounds!
    16. #36
      Lawrenceburg, TN
      HEY? what happen to all my pictures? oh now there back
    17. #37
      OK
      The car looks great! It sure has came a long way.
    18. #38
      Lawrenceburg, TN
      Quote Originally Posted by Andrew McBride View Post
      Thanks Andrew!!!
    19. #39
      Lawrenceburg, TN
      adding a Heater
      I wanted a heater since I drive the car every day to the shop so i found a dual inlet for the heater lines
      and then I ordered a under dash jeep heater from summit and ran some flexible hose to test it before I seal the heater ducts together
      here's the heater lines coming thru the firewall
      I placed the three speed switch in the cigarette lighter hole and used the factory bezel! for a cleaner look
      and heres how the center dash looks
    20. #40
      Apr 2008
      Country Flag: Sweden
      Is it possible to get a pic from the rear showing the shocks? I'm curious on the emergency brake wire routing related to the shocks. I did this last year and had terrible problems with the wire running straight into the shock. Thanks
