    Page 8 of 30 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 18 ... LastLast
    Results 141 to 160 of 586
    1. #141
      Aug 2011
      Michigan
      Excellent transformation! Good work!
    2. #142
      Aug 2010
      Ft. Leavenworth, KS
      Where did you get the gas cap from, and how difficult was it to install?
      GRIFF
      '67 CAMARO
    3. #143
      Lawrenceburg, TN
      the Gas cap is from Ride Tech, it was an easy install
    4. #144
      Aug 2010
      Ft. Leavenworth, KS
      Thanks for the response, love the car and appreciate the excellent progress reports. Hopefully I'll get mine on here soon.
      GRIFF
      '67 CAMARO
    5. #145
      Nor Cal
      Very cool Rod... are you gonna get up there and get over to the GG AutoX next month?
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
    6. #146
      Dec 2009
      El Dorado Hills
      Hey Rod, How are ya!! Cant remember last time I posted here but looks like you've been busy. How do you like the Spectre air cleaner? Looks really cool and am thinking of using one for one of my future builds.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
    7. #147
      Oct 2011
      Awesome build!
    8. #148
      Lawrenceburg, TN
      Quote Originally Posted by Flash68 View Post
      Oh hell yes Dave The car was running awesome till I smoked the trans
      Quote Originally Posted by Gitter Dun View Post
      I like the Cold air intake from Spectre works well!! and it looks like the early smokey Z28 cowl plenum intake Chevy developed in early SCCA and Trans Am, which is an awesome bonus
    9. #149
      Houston, TX
      I just received my new Tall ball joints last night from Power Performance Motorsports, good looking parts with a cast top and ring-retained dust boot, I will get these on tomorrow or Monday if the rain lets up, and then I will test them with daily use and at the GoodGuys AutoX in 2 weeks
      here's a close up of the top casing, nicely made with a grease fitting
      Rod,
      Do you have the part number for the tall ball joint? I looked at proforged web site and was not able to find it.
      Tu
      Tu Ho
      Firebird V2-LS swap
    10. #150
      Lawrenceburg, TN
      The part number is 101-10016
      heres a linky to them tall ball joints
      hope that helps
    11. #151
      Houston, TX
      Thanks Rod. How do you like them so far? The boots on the ones that came with my GW upper arms leaked grease all over the suspensions, so gave me an excuse to go to tall ball joint.
      Tu Ho
      Firebird V2-LS swap
    12. #152
      Lawrenceburg, TN
      The tall ball joints work great with the Global west upper arms, the DSE lower arms, Hotchkis coil spring and sway bar you can see from these pictures the suspension goes slightly negative in corners like needed, this year (2012) I will add the Guldstand mod to see how the set up works then I think a little more negative (and a little wider front tire) and Plain Jane will be unstoppable
    13. #153
      Oct 2009
      Garland, Tx
      I'm interested to see how the tall spindle/ball joint works with the Guldstrand mod. I thought they both accomplished the same thing.
    14. #154
      Orangevale, Ca
      Very inspiring build, great job...
    15. #155
      Lawrenceburg, TN
      Plain Janes (1sickT8) seat and engine shots
      just some quick seat and engine pics
      seats fit and look great in the car and work perfect with the Morris Classic seat belts
      corbeau pump up lumbar
      heres the Spectre air box in place fits like a glove behind the Hotchkis bar and just over the MSD dizzy
    16. #156
      Jun 2011
      Ohio
      Car looks great,I love the way that spectre airbox looks on there!!!
    17. #157
      Dec 2009
      El Dorado Hills
      Awesome work Rod. Love to see you trying different stratagies to get her to stick up front.
      Seats and engine compartment look great!!
      Gaetano Cosentino
    18. #158
      Nor Cal
      Rod, looks great. Which Corbeaus are those?
      You able to come meet up next Saturday and hang with us at Rich's shop?
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
    19. #159
      Lawrenceburg, TN
      awesome!! I will be there car permitting! Plain Jane's been a little picky lately
    20. #160
      Lawrenceburg, TN
      Plain Janes (1sickT8) Heart Gives up
      OK just as the title says, my car Plain Jane engine started burning oil last weekend (james bond smoke cloud style) just after a visit to the BBQ at Road Touring customs, (which by the way Rich was AWESOME! thanks bro) so I pulled the heads valves were fine, seals fine, guides fine, so then I pulled the rest of the motor, and I have a bad piston skirt that cracked a chunk off and damage the cylinder wall, heres my question!!!!! I have 2 motors to choose from as a replacement
      1) is an torquey LS 327 from GM with ls 6 reworked heads and a cam - about 355HP
      2) is a bone stock Ls6 completely stock --------------------------- about 400 HP
      going with the LS plunge I have collected a good list of parts for the swap and the swap was supposed to happen at the end of the year not the start
      so which engine do I choose?????
