    Page 6 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 ... LastLast
    Results 101 to 120 of 586
    1. #101
      May 2002
      Northern California
      don't worry, that nice red caliper will hide it well. You can always paint it black if you like.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    2. #102
      Lawrenceburg, TN
      Vince
      I found the stainless in shiny, then blue and red, but I cant find black? if I paint it the flex will chip the paint?
    3. #103
      Mar 2010
      The LED tail lights were from Speedway Motors work great just remember to get a LED(no load) flasher to go with them or you wont have turn signals!!
      i actually bought the same the lights. after i installed them i was amazed at how bright they were in comparison to stock. i went for a drive later on and no turn signals. i was like "what the duece?". then i remember that led lights draw practically no amps and i needed the no draw flasher. panicked for nothing, lol.
      car is coming along nice. where did you pick up the billet grill and how is the fitment?
    4. #104
      Lawrenceburg, TN
      Quote Originally Posted by LV42DAY View Post
      the grill was from Classic Industries the fit was very good but I did redrill the headlight cover mounting holes if i used there holes the covers were super crooked...??? the center grill fit fine
    5. #105
      Mar 2010
      sounds good. thats the one i been eye balling for the past two months. ive been trying like hell to get them to send me a photo of "phantom" grill but apparently they have to make it which takes forever. i dont want to spend $200 on a part, then be forced to wait for it and then potentially not even like it when it shows up. i might stick with the three piece rs grill. its priced pretty good at 120 and a hell of a lot nicer then the stock plastic.
      *actually called them just after i posted this. they are sending me a photo of the phantom grill finally, only the grill not actually mounted, but its better then nothing. guess i will make my final decision once i see it.
    6. #106
      Lawrenceburg, TN
      New QA1 shocks
      like they say the car is never done! so here are the new QA1 shocks
      and I also picked up a stinger hood and started blocking it for paint
      also reinforced the hinge area and pin area with carbon fiber
    7. #107
      Lawrenceburg, TN
      so Rob about those D-52 wilwood calipers you asked about
      Quote Originally Posted by ROBS6T8 View Post
      Let us know how good they work. i ws hinking of purchasing some too. I'm not ready to throw down the big bucks yet.
      I don't want to say anything bad about the calipers, there very nice, well machined, lightweight, but after a power bleed, then a manual air bleed just to confirm, then driving them for 2 weeks to make sure there settled in, they feel exactly like the factory ones i removed, I ran them at a SCCA club run and just from the feel?? and seat of the pants racing, there the same as factory, there might be more clamping force but I can't measure that, so if you have factory, keep them unless you want the look, because the performance just driving them, in my opinion, they feel the same, it should be better they are 2 piston vs the the factory single piston
    8. #108
      Feb 2010
      Central NJ
      I have the same ones on the front... that kind of sucks about the performance.... (still havent driven with them yet for me to judge)
      What version d-52 wilwoods did you use? the (2) 2" pistons or the (2) 1.25 pistons setup?
      thanks for the feedback on the brakes btw....
      -Sean
    9. #109
      Lawrenceburg, TN
      Quote Originally Posted by sr73bu View Post
      -Sean
      I'm running the 1.25 pistons, thats what wilwood recommended since i have 4 wheel disc setup, don't get me wrong about the performance its still good, but the factory d-52 setup i had was setup perfect with Motul RBF 660 fluid, hawk pads, (it easily out stopped my porsche) I just expected some sort of change, you know a little more bang for the buck
    10. #110
      Feb 2010
      Central NJ
      I've got the 2" piston setup / rear drums (for now), so I guess i'll have to see for myself... thanks for the info, and keep up the great work!
      -Sean
    11. #111
      Lawrenceburg, TN
      Power Performance Motorsports tall ball joints
      I just received my new Tall ball joints last night from Power Performance Motorsports, good looking parts with a cast top and ring-retained dust boot, I will get these on tomorrow or Monday if the rain lets up, and then I will test them with daily use and at the GoodGuys AutoX in 2 weeks
      here's a close up of the top casing, nicely made with a grease fitting
    12. #112
      Templeton, CA
      Rod, thanks for the info on the calipers. I too have drums on the rear. Maybe I'll see what Sean has to say.
      Nice looking shocks. I'm saving my pennies or some Varishocks. I've been saving a lot of pennies. This thing will never be done!!
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
    13. #113
      Lawrenceburg, TN
      I don't think that there ever done, we just keep pluggin
    14. #114
      Lawrenceburg, TN
      Power Performance Motorsports tall ball joint 1968 Camaro install
      after removing the wheels heres the old upper ball joint on the global west arms
      I removed the cotter pin and loosened the castle nut to the bottom threads and the placed a jack under the lower control arm
      a few knocks with a pickle fork and hammer
      now a loose upper arm
      after removing the ball joint here you can see the differences
      a quick trial fit and the 2 front holes on the ball joint don't line up correctly with the arms holes or vice-versa, here you see the angles
      so a easy ream of the holes with a drill
      and a little touch up paint so the raw metal wont rust( she is a daily driver)
      heres the ball joint back in and ready to go, now on to side 2
    15. #115
      Lawrenceburg, TN
      D-52 caliper update
      getting ready for GoodGuys I swapped in some ceramic rebestos Pads and did a light pad bed in, and headed to the event! and after a few runs the brakes were stopping hard!! really HARD! man! they really work well now! and after a weekend of hard driving the brakes work awesome, I guess they just need to be abused really hard to come to life
    16. #116
      Templeton, CA
      Hey Rod, Merry Christmas! Thanks for the update on the brakes. I went searching for your project and just read the entire thread once more. A very down to earth read for all of us do-it-yourselfers! I have a few more questions for you. What size tires and wheels are you running? How did you paint your bumper? Did you take all the chrome off first? I'm painting mine body color as well. And the D-90 stripe, did you have a stencil or just lay it out yourself? This is also going on the rendering I'm having done. More motivation! Thanks.
      Robert
    17. #117
      Sep 2009
      Great Job on the camaro...like the new wheel choice.
    18. #118
      alpine ca
      thank god you replaced those corvette wheels my 2 cents anyone who runs spacers (that big) they are just asking for the wheel to fall off they are death traps car is looking great and nice build
      john
      BUILD LINK
    19. #119
      Nov 2010
      What did you do with the wheel spacers when you changed wheels? I might be interested.
    20. #120
      alpine ca
      Quote Originally Posted by tdm119 View Post
      BUILD LINK
