    Page 16 of 30 FirstFirst ... 6 11 12 13 14 15 16 17 18 19 20 21 26 ... LastLast
    Results 301 to 320 of 586
    1. #301
      Oct 2007
      Union Mo
      Rod the updates are looking good. I have enjoyed looking at your website. Lots of great info on there. Everyone needs to check it out. Thanks for posting Eric
    2. #302
      san diego
      I had a chance to work with Ridetechs guys back in November during the DelMar event and there ridetech fox shocks have been on the market for a while I was using another adjustable shock and the ridetech mono tube was smoother with a larger adjustment range, and I wanted to stay with the adjustment feature still
      Oh, so the hotckis are non adjustable? Makes sense to me.
    3. #303
      Lawrenceburg, TN
      Quote Originally Posted by Bryce View Post
      correct, and I don't have a lot of adjustments on my suspension, just the adjustable shocks and rear sway bar as far as easy adjustments, then there's rear ride height (to change the roll center) with the blocks
    4. #304
      san diego
      Thanks Rod.
    5. #305
      Lawrenceburg, TN
      Season warmup!
      to be ready for the season, I tested the car and registered in and autocross driving school with a few friends a tune up for me and the car (Plain Jane)
      good fun
      and silly friends
    6. #306
      Lawrenceburg, TN
      off to Run To The Coast
      my season warm up didn't go as well as I wanted, I will just say the tires I had for this event... sucked..... I have run the Falken rt615k for a year and have never had a problem, I won some tires at an event and since they where new (but not Falkens) I figured how bad could they be (since this company was promoting them as a autocross tire just a year ago) the car was so loose and out of control it was scary and I was in 30th spot, so Sunday before the event Big O tires were mounting 2 front different tires for me in an attempt to save my weekend race, and I went back to the track and the car was better but not good but I dropped a second on my time and moved up 10 spots to 20, lesson learn "That Company will not fool me again"
    7. #307
      Lawrenceburg, TN
      Just a quick update for the weekend!
      I upgraded to some cool Hubs i picked up from gnitro! nice and light weight and then I changed the front wheel width from 17x8 to 17x9.5 and now the Camaro runs 275-40-17 all four corners, I will get a little pic up later
    8. #308
      Glad they work for you sir...Car is looking great, the hubs should be worth 40hp
    9. #309
      Lawrenceburg, TN
      Quote Originally Posted by qnitro View Post
      ha ha ha 40HP! I could use it everyone I race with added HP this year, Goodguys is around the corner, you going to have the silver bullet done? if not come out and ride the track with me a few times just to get youre fix, if it is done, I want a ride in it
    10. #310
      Lawrenceburg, TN
      So Cal Challenge (EVENT 1)
      Last week at the last minute I decide to run the So Cal Challenge events, so I woke up saturday morning at 2:00am drove 550 miles to the event rolled in at 8:15 am and tech had just started at 8:00, so I was unloading the car during Tech, My girl friend also raced the day, I finished top 4, just beaten by Ridetechs 33, Brett Cambells Fab 53 Roadster Camaro, and Dale's Sunbeam Tiger
      great event Thanks to Rob, Black ink media, the sponsors, TCI, comp cams, ridetech and the rest!
      it was a good start of the season!
    11. #311
      Aug 2008
      Iowa
      Love this whole thread Rod! You are making quite the name for yourself in autocross circles. I read in one of the mags (car craft?) that said you were running Sanderson headers? True? I thought this might have been an error from the magazine as I did not see anything in regards to them in the thread. If you are running them, which model? and do you recommend them? Thanks, Mark
    12. #312
      Lawrenceburg, TN
      Quote Originally Posted by armourmark View Post
      That was not a misprint, I am running Sanderson Headers, One thing that drag racers and road racers have in common, is a need for power, but that is where it ends. Drag racers want peak HP and but for my PT car I need a larger power band range. Most headers are the common long tube 4-1 design that promotes maximum peak horsepower, with the common primary tube diameter of 1 3/4" for quick exhaust scavenging and a collector size of 3" seems to be the most often offered. Both of these measurements are really bigger than needed for a typical SBC or LS engine (even my 6.0 LS is just 363.9 cu in, hardly bigger than a 350) in most uses. In my case, with a 6.0 LQ4 LS engine and a focus on low-end and mid-range (this is an autocross car after all!) - the vast majority of the headers out there just weren't the right fit for me (there desighed for top end), at least not as I see it, here's why:
      When I built the car the first time with big headers & big tubes (3") & big mufflers, the car was noisy but not fast-- pipes hanging down dragging on dips, and making it virtually impossible to drive over train tracks.
      When I switched to a smaller exhaust pipe (2.5") the car was peppy around the track; next a switch to the cheapest header I could find with small primary tubes (I used a cheapo summit brand exhaust for $79.00) and car was even faster off the line than I could have hoped for, but still hung down below the frame.
      So this is what I need:
      •Ground clearance. not hanging below the frame. we have bumps and dips while racing.
      •Good low-end and mid-range speed. I should have more acceleration at low engine speeds than the competition
      •Low weight. Header weight is up on the nose, and top-heavy
      I needed a header that *should* meet these requirements. Being lucky enough to have a header manufacturer a mile from my shop helped the process a lot!
      I explained my needs to my friends at Sanderson Headers and after 2 weeks and several fittings, I ended with the header design with a Primary Tube Diameter of 1½", a Collector Diameter of 2½", and weighing in at just 13 LBS complete with bolts and collectors in plain steel (no-coating), dropping another 25+lbs off the nose of my Camaro "Plain Jane".
      This design is now available from Sanderson Headers as Model # V8RLS1 in plain steel or ceramic coated and fits perfectly in a First Generation Camaro with an LS engine swap.
      I have an AGR power steering box and the stock clutch linkage (Z-bar) and this header configuration clears around both.
      They have been on the car since febuary 2012 and I havent had one issue
    13. #313
      Jun 2005
      Surprise, AZ
      Country Flag: UK
      Awesome thread Rod, watched the SoCal Challenge live on Bangshift while working on the Firebird the other weekend, it was so cool felt like I was there! Your car is looking and running great, had a blast yesterday at Goodguys Scottsdale, missed seeing you guys.
      Chris.
      68 Firebird 400, 325 cfm Edelbrock heads, .628" solid roller, TKO 600 w/3.73's, Ridetech TruTurn and 4 link with HQ coil overs, Hotchkis Swaybars, Guldstrand mod, Baer 12" PBR 4wdb, Detroit Speed Subframe Connectors, 18x9.5 & 18x12 Apex EC-7's.
    14. #314
      Aug 2008
      Iowa
      Thanks for the clarification Rod. I know what you mean about the parts being a "one size fits all" to accomplish peak HP, definitely have to do research on some parts before purchasing.
    15. #315
      Lawrenceburg, TN
      Here,s the front wheel update.....width change from 17x8 to 17x9.5 and now the Camaro runs 275-40-17 all four corners you can see there still just inside the fenderwells
    16. #316
      I will be there but silver bullet wont.. She is close, we actually bumped the motor, and are just finishing wiring it up.. I will take up on the ride, I will come by and see you..
    17. #317
      san diego
      Those tires should help!
    18. #318
      Jul 2010
      Monticello, MN
      What is the backspace you are running Rod? Is it the exact same wheel/tire combo as the rear?
      That looks great!
    19. #319
      Lawrenceburg, TN
      I agree I was shooting for a square wheel setup, The car was pretty balanced with the 255/275 combo, but with a 275/275 combo the extra 1.7 inches on the ground should be great for turn in
    20. #320
      Sep 2012
      San Mateo, Ca.
      Rodney,car looks great! Thanks for showing me your car the day I bought some parts. I showed you a pic of boxing out my front fenders on the Lark. Did you have to do yours?
      Marcell
