    Page 11 of 30 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 21 ... LastLast
    Results 201 to 220 of 586
    1. #201
      Mar 2012
      San Francisco Bay Area
      painted the Rear bumper yesterday and installed it today, now I have to do the front bumper!!
      When??
    2. #202
      May 2002
      Northern California
      Quote Originally Posted by Suzy-Homemaker View Post
      When??
      09-02-2010 lol
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    3. #203
      Nov 2010
      Ventura County CA
      I'd really like to see a repeat of this photo with the new LS engine (LQ4?). Really like the old-school look you've pulled off. Running the aircleaner to the cowl looks very trans-am. Only thing I'd change if it were mine is to de-logo it - looks classic but the giant "Spectre" and "Hotchkis" logos take away from it a bit I think.
    4. #204
      Lawrenceburg, TN
      easy LS power steering bracket (LQ4 truck style)
      I was looking to keep the old school look so I made or modded brackets for my LS install and here is the power steering one below
      original truck PS and alt bracket
      cut the bracket with a band saw or sawzall
      smooth out the cuts with grinder or flapper wheel
      OK heres the cool part! the original pump casing just bolts in you might have to grind the bracket a little around the pump cap and then bolts right to the block
      just add paint and it will look awesome
    5. #205
      Lawrenceburg, TN
      heres the updated look at the LQ4 power steering modified bracket
    6. #206
      Lawrenceburg, TN
      Quote Originally Posted by TheBandit View Post
      Heres the old
      heres the new
    7. #207
      Lawrenceburg, TN
      Plain Jane (1sickT8) my 1968 Camaro goes under knife (minor touch ups)
      Plain Jane (1sickT8) my 1968 Camaro goes under knife for just touch ups, I haven't updated here in a while its been very busy. I have been tuning and tweaking the suspension and the car has done very well at the last couple of events, HOW WELL YOU ASK? enough that John Hotchkis ask me to Join their H-Team (awesomeness) since I was friends with some of those drivers anyways, now I have one more excuse to hang with them
      It comes at the same time I have some time now to finish some loose suspension ends. before some more big events that are coming up, one of them tweaksI want is a spherical rear leaf spring bearing upgrade I picked this up a few months back about the same time I blew up the old motor, but the cars running great now so time to update
      you can see it comes packed very well and after talking to both David Pozzi and Keith Smith at the last few events this is one of those little add-ons that helps improve traction, and roll control around corners
Size:  169.3 KBName:  GEDC9628.jpg
Size:  199.1 KBName:  GEDC9629.jpg
Size:  190.8 KBName:  GEDC9630.jpg
Size:  278.0 KBName:  GEDC9632.jpg
Size:  229.0 KBName:  GEDC9633.jpg
Size:  157.8 KBName:  GEDC9634.jpg
Size:  198.3 KBName:  GEDC9635.jpg
Size:  200.1 KBName:  GEDC9636.jpg
    8. #208
      Birmingham, AL
      Great looking parts and I like that engine bay.
      Stephen
    9. #209
      Lawrenceburg, TN
      Project Plain Jane (1sickT8) meets Guldstrand
      I know, I know, I know, this one of the first mods many do, but I waited to get the car as dialed as possible before doing it, and for no real reason other than just being stubborn, I have done it to others cars and there cars just worked great, but I held out for 3 years of racing and now that I have the car well tuned, I have added the Guldstrand mod to the front, Awhile back I ordered the templates from **** Guldstrand he tossed in some decals and a copy of a magazine article all about the mod
      stuff from **** <----I guess I cant use Mr Guldstrands name the forum blocks it out immediately!! lets try this
      D I C K Guldstrand
      Templates on the car
      Pilot holes drilled
      Knocked out the old bolts and replaced them with new GM (NOS) bolts I purchased a few years back
      heres my home made knock tool I have installed all kinds of crap with this gizmo
      bolts out
      new ones in, arm in location and new bolts in place
      suspension back together
      another Driveway job!
    10. #210
      Jul 2012
      eden ga
      Nice build make me want to go work on my car now
    11. #211
      Lawrenceburg, TN
      Basic results of the Guldstrand mod
      I see alot of people ask should I do the Guldstrand mod or not, and many reason that they wont be racing so they dont need it, but I will tell you there are a few ways to improve the front suspension camber gains on your front double A-arm suspension.
      #1) You can shorten the upper control arms = money
      #2) You can install a taller spindle or Ball Joint = money
      #3) You can change the pivot points of your control arms = time
      #3 is the cheapest option (since you can't pay less than zero) simply drilling 4 holes and by using the template designed by Guldstrand it will lower the upper control arm pivot points by .75 inch. there are many of the templates avalible for free on the net or you can order yours from Guldstrand directly but they will charge you (well worth it youre getting a little peice of history) I waited to do this Mod till I already added tall Ball joints, tube arms, fat 255 front tires, Hotchkis Handle bars, the car was very dialed and has done well at many events, so doing the mod to the car now will show me what the results really are
      After the Guldstrand mod even during just daily driving over the last few days (to and from work 10 miles each way), large bumps and dips are less jaring to the front suspension, the nose of the car dips less when braking and raise about the same under acceleration and on top of that there's some bump steer reduction(a little bonus)
      I would highly recommend this simple procedure for any camaro even in stock form or as a race car the mod makes a safer driving car, in the next few weeks i will get some track time to really test it, after the first track day I will add the new Proforged tall Tie rod ends and see how those work
    12. #212
      Dec 2011
      Livermore, CA
      Hey Rodney, this is just for first gens right? BTW, lost the use of my right shoulder for 6 months, bout a year recovery so no autocrossy for me this year (boo), but was spinning donuts with my right arm in a splint...right side too. The t56 conversion will be on hold a while...
    13. #213
      Lawrenceburg, TN
      sorry yes that mod was for first gen camaros/firebirds, the suspension on the second gen was waaayyy! better all those angles were tuned by then, DUDE Mike get that shoulder put back together (just gives you a year tweak the ride!) then come out and run it
    14. #214
      Jun 2006
      Kent
      Country Flag: UK
      In this picture I'm testing a new Distributor-less ignition I ran it a few auto cross events but it need some dialing of the computer
      Hi, I know you have now opted for an LS motor, but did you manage to do any more testing of the DIS8 system?
      Great build by the way
      Cheers,
      Mark
    15. #215
      Lawrenceburg, TN
      Quote Originally Posted by uk68327 View Post
      Cheers,
      Mark
      The DIS8 worked great! the final product I had was very smooth and gave tons of smooth top end at 65 on the freeway the DIS had amazing pickup for passing, at idle the car was less loppy(is that a word) it evened out the cam at 650idle
      I used to see these all the time on sand rails and offroad racers, but this was first I seen on a V8, I switched back and forth to get a good feel for the product and never had a problem, it was easier to set up than the distributor
    16. #216
      Jun 2006
      Kent
      Country Flag: UK
      Thank for you the feedback I am quite interested in the DIS8, would like to run coilpacks, either the DIS8 or Megasquirt (ignition only).
    17. #217
      Lawrenceburg, TN
      that DIS is nice because its the crank trigger, computer and now they have added the dwell adjustability to it, and I had the coil packs on the valve covers for a while it looked pretty cool, and then I put them on the fire wall to hide them
    18. #218
      Oct 2010
      Santa Ana, CA
      How much dose this lower or raise the front of you camaro? if at all
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
    19. #219
      Lawrenceburg, TN
      Quote Originally Posted by stilo View Post
      I didn't do any measurements before the Guldstrand but it did drop the car about about 1/2inch from the tire to fender clearance
    20. #220
      Lawrenceburg, TN
      Hotchkis Swivel Max Bushing upgrade
      this weekend was another weekend to get the car suspension tweeks done, so I started with the spherical leaf spring bushings to increase suspension articulation to improve cornering traction,
      out with the old rear shackles and in with the new
      out with the front eyelet bushing and I pressed in a spherical front bushing
      looks good right!
      small weld bead to keep the housing from moving
      back into the leaf spring box
      back into the car
      also some new rear tires arrived.... wahoo these look awesome!
