    Page 1 of 30 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 586
      Lawrenceburg, TN
      1968 Camaro Project Plain Jane (1sickT8)
      I have been watching many builds and I guess its my turn to chronicle my car, Plain Jane (a.k.a. 1sickT8) well It started out as a lucky find in Foster city California, An older lady wanted to sell a camaro for $100, so i thought I would go look at the car, HECK for 100 dollars I thought even if it was a crapper there's got to be more than 100 dollars worth of parts on it for resale? right?
      after she opened the garage I thought,,, I could work with this
      nothing inside the car but a few parts! hey a FREE Turbo charger!
      and a few more parts in the trunk
      Time to get it on the trailer
      a little rain, whats an adventure without rain
      one last look around the ladies garage and I found a power glide trans, a drive shaft and a back seat!! that's a start!!
      Lawrenceburg, TN
      Got the car home with the help of a friend (thanks Ante) he's only 19 and a great kid- at this point I start taking the car apart just to see what I have to start with
      with the frame out, I started clean up, my girlfriends son (Kyle)was a great help turning some wrench and lifting the body parts
      Oct 2009
      Houston, tx
      Good Luck with your build!
      I love these kinds of builds, the starting from a rusted shell and building from there. You have all the options in the world and you can turn the car into anything you want!
      The threads where people start with a tired car with a little rust and tear them down just aren't as romantic.
      Oh, and I am sure you know that it costs like twice as much to build them as apposed to buy them, so get ready!
      I can see the LS9 in your future right now (wink)
      David
      1968 Camaro in many pieces
      Lawrenceburg, TN
      Thanks MARO Having the blank slate is tough!
      here's the front sub frame Stripped down
      First I weld all the seams on the frame for reinforcement and then I sent it to Peen Rite for a shot peen to help reduce Resistance Fatigue (torsional resistance) and here's the frame after peening and some charcoal grey paint
      while the frame was away relaxing(pun intended) in sunny southern california,
      We built a Wooden body trolly to roll the car around the garage and roll it outside
      and Here my girl friends son Kyle is sand blasting the body outside and working on those lower quarters rusty areas(he's a quick learner)
      as the day worn on and it became dark Kyle moved on to firewall clean up inside the garage, Radio going in the back ground and a portable heater
      Lawrenceburg, TN
      time to replace some sheet metal first the rear floor sections, and the the tail panel
      that was easy!!! but this tail panel!! Wow!!
      drill out all the spot welds
      and more welds
      gotta fit and fix it all now
      Tail panel almost fitted!!
      Jun 2009
      Cape Coral, FL
      Great build so far! Man I really need to think of a good project name lol
      What are the plans for the car?
      Jan 2010
      Oxnard Califas.
      Work looks good, nice to see the young guns involved. Not many teenagers around here seem to know anything about old steel. Good job.
      The Blurr!
      Oct 2009
      Houston, tx
      Could you tell me more about what you did to the front frame?
      David
      Apr 2007
      Utah
      Looking great Awesome that you are involving the kid. Make sure you teach him about safety gear. Sandblast silica can be hazardous to your health. But awesome work.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
      Lawrenceburg, TN
      The young Guys have been a great help from day one just spending hours picking up the car, collect the parts, eating the lunch I bought them !! and the Ideas they have! whew!
      Lawrenceburg, TN
      Quote Originally Posted by 1968Maro View Post
      the factory frames are just stitched welded every few inchs, I simply welded all the seems on the frame completely, this helps stiffen the frame, then the frame was SHOT PEENED, its almost like Abrasive Blasting but with Abrasive Blasting their intent is to clean the material using different cleaning medias, when you Shot peen it is a cold working process (using a specific material, spray pattern and pressure) in which the surface of a part is bombarded with small spherical media called shot. Each piece of shot striking the material acts as a tiny peening hammer, imparting to the surface a small indentation or dimple. In order for the dimple to be created, the surface fibers of the material must be yielded in tension. Below the surface, the fibers try to restore the surface to its original shape, thereby producing below the dimple, a hemisphere of cold-worked material highly stressed in compression. Overlapping dimples develop an even layer of metal in residual compressive stress
      I worked in a aluminum manufacturing plant and we also peened Scuba tanks that were used for deep dive projects (to increase there strength) It makes the frame material harder and relieves any torsional stress (twisting)
      peen rite describes it better and more complete on there sight
      Lawrenceburg, TN
      the tail-panel is on firewall is getting smoother time to set some fenders on the car
      shot some rust proofing paint under the dash on the headliner area and on the roof
      Lawrenceburg, TN
      the firewall is almost smooth and I just need a block off plate to weld in the AC hole and then shoot some color here so I can start reassembly
      here's the color under the dash
      and the subframe looks awesome now going back into the car
      Lawrenceburg, TN
      now the wiring I picked up the American Autowire Classic update kit, it came pretty complete and for my empty car the more complete the better!! and while I'm in the car a little sound deader needs to get put down also
      super nice fuse block and it fit like factory!!
      for sound deadner I used Thermo Techs, cool it series stuff nice
      Suisun City, Ca.
      Very nice progress, and great to have the family involved.
      Mike
      Lawrenceburg, TN
      So I'm doing the ultimate multi-tasking, I work on the wiring during the day light hours and when it gets dark later in the evening I work on assembling the engine
      here's the motor (actual this is version 1.0) I changed the layout later
      and here's the Trans it a Borg Warner Super T-10 out of a 70's vette with a wide ratio, I bought it used and then had to rebuild it
      here I am learning as I go! that was the key to this build every thing had to be done, or at least attempted by me! I didn't want to farm out a lot of work
      and now the engine goes in
      Lawrenceburg, TN
      Quote Originally Posted by mdprovee View Post
      Thanks mike!! even the girl friend is into it
      Dec 2007
      British Columbia, Canada
      What he said! ^ Awesome find!
      Laine O
      LIVE LOVE DRIVE!
      Feb 2010
      Modesto California
      awesome find and awesome build good sir.
