    Results 1 to 7 of 7
    Thread: Power windows
      Nov 2009
      Fort Walton Beach, FL
      Power windows
      I'm wanting to put power windows in my 73 Nova (1 pc door glass). The electric life kits show direct replacement regulators for 1st gen camaros but nothing for 68-up X bodies. Does anyone know if the factory used the same regulator for the X bodies as the F body? If not, can anyone recommend a manufacturer for a kit for this car?
      Thanks,
      Kevin
      73 Nova
      355/TH350 (soon to be T56)
      07 Trailblazer SS AWD
      Stock (for now)
      Jan 2010
      Tornado Alley, OK
      Jorge
      www.estrada-armory.com
      May 2008
      CT
      THis might be over the top. Both regulators are almost the same. I put the 73 glass in my 69 and people have used 73-74 doors and used the 68-72 reg. Everything bolts up except for one bolt. The 73 regulator is longer. What would happen if you bought the power 68-72 reg. cut it/weld it to your 73 reg.
      Bryan, 69 nova LS3 w/T56 Ridetech subframe
      Nov 2009
      Quote Originally Posted by 69bigblock View Post
      Good idea Bryan, hadn't thought of that. My only concern is cutting and welding a $500 pair of regulators. At least that's what the kit that nu relics sells goes for. I can't seem to find many kits for the 68-72's, that's why I was hoping the first gen camaro with the one piece door glass (68-69) may be a possibility. Thanks for your input. I will definitely consider it.
      Kevin
      73 Nova
      Stock (for now)
      CT
      Maybe if someone that has a 69 window regulator can give some dimensions we can compare them to the nova ones. I some 69-72
      and 73-74 window regulators out of a car so I can check those..
      Nov 2009
      TTT for anyone with info on a 68-9 camaro window regulator (dimensions)
      Kevin
      73 Nova
      Stock (for now)
