      Jul 2009
      Central PA
      72 Chevelle Air suspension choice
      I had just done a thread on whether to use drop spindles with a Ride Tech air system. Got that answer, Thanks.
      The other question was has anyone used the Ride Tec system vs the Air Bag It system? There is a big price difference due to the air bag it system using stock a arms and such but the shock relocation is going to be tight. If anyone has good or bad to help out I appreciate it!
      72 Chevelle Big Mutha Thumpr, 496 Strokr
      Des Moines, IA
      All I can say is I suggest you use the following (regardless of supplier)
      -trusted air spring manufacturer (preferably one who has sold millions of air springs and tested them into the tens-of-millions of cycles)
      -DOT approved EVERYTHING! If you skimp on air line, fittings, valves, etc you'll be disappointed, and UNSAFE! The DOT has mandated specifications for all these parts as all semi-tractor rigs on the road use air brakes. If the brakes fail, it's a big deal.
      I'm not saying to buy one kit over the other, I'm just suggesting you do some research to ensure you get the best parts for your money. I don't want anyone unhappy, and I sure as hell don't want anyone put in harms way!
      Aug 2003
      For Air Suspension, We only sell ridetech. No one else puts their stuff through the torture Ride Tech does.
