    Page 10 of 23 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 20 ... LastLast
    Results 181 to 200 of 454
    1. #181
      Utah
      Hey Dalamar, I remember you from the sn95 forum when I had a '94. I'm in Utah too. I need to drop by your place and check out this '67. Wow! You and your dad have done tons of work. Amazing! Definitely be following this build.
      Chris
    2. #182
      May 2009
      Quote Originally Posted by Dalamar View Post
      Are you going to go wide-body on the back end?, what are the plans for the rear quarters?
    3. #183
      Jan 2010
      SLC. UT
      Quote Originally Posted by Ripped View Post
      We're going to widen the rear quarter.
      this car will have a low stance.
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    4. #184
      Utah
      So, Dalamar, any update on this badboy!?
    5. #185
      Mar 2010
      updates?
    6. #186
      Jan 2010
      SLC. UT
      No updates of yet guys, sorry.
      my summer has been super busy! now that the kids are back in school, it should calm down some.
    7. #187
      Feb 2010
      Plainfield, IN
      Bippity boppity bump for an update?
      1969 1/2 Maverick
      4.6 DOHC, Mustang II front, T56, & Cobra IRS
      Custom Interior in the works.
      http://www.cardomain.com/ride/2200206
    8. #188
      Jan 2010
      SLC. UT
      it is about time for an update, and about time we worked on this project for that matter.
      What we did over the weekend.
      Wiper linkage. mounting the motor and linkage from the 97 doner car.
      here's some pics.
      The motor is accessable from the bay, and the rest will be welded back under the cowel sheet metal!
    9. #189
      Jan 2010
      SLC. UT
      pieced in the tunnel brace and tied it into the seat crossbrace
      got it up in the air to weld all the joints on the bottom side.
      I still think the bottom of this car is more interesting :P
    10. #190
      SF Bay Area
      Great to see that this project is still moving along - it's looking good!
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    11. #191
      looking good Jeff! good work!!!
      Jan 2010
      SLC. UT
      last weekend's damage:
      Metal prep'd & Pour15 the front inside
      Put the front suspension back on:
      heater core bolts right in!
      Front tires on
      Check out the Hotness:
    13. #193
      Dec 2008
      Columbus, IN
      Awesome project jeff!
      '66 Mustang
      '67 FireBird https://www.pro-touring.com/forum/sh...light=firebird
      '68 Barracuda
      '69 Mustang Mach 1
      '97 Mustang Cobra
      '04 Mustang Cobra
    14. #194
      Charlotte
      Whats the height of your garage ceiling?
      Car is looking awesome...
      2014 Chevy SS LS3 / 4 Door
    15. #195
      Jan 2010
      SLC. UT
      Thanks Cobraguy.
      Bonecrusher, it's 10'
      would have loved to go higher, but couldn't.
      Looking at some Dampifier to put down on the interior to make it nice and quiet inside.
      has anyone used that stuff?
    16. #196
      Oct 2009
      Ithaca, NY
      I used Dynamat on the '65. Every easy to install, and works pretty good as well.
    17. #197
      Oct 2010
      SLC
      Like all the custom fab. should be an awsome car. Just a heads up, I had the same front end on my '70 and had some issues with the coilover mounts. The adjustable pieces would never stay in place and I eventually had to tack them to keep them where I wanted them. and over time the vertical piece that holds the coilover mount began to bend inward, so you may want to reinforce that if possible.
      I also had a little trouble keeping the Rod and Customs supplied U-joints tight on the sterring shaft. nothing ever came apart, but it was a neusance since it frequently caused there to be a little play in the wheel. I had the manual rack so I'm sure there was a lot of force put on the steering shaft at times. Hopefully you will have better luck with the power rack.
      Zach
    18. #198
      I've had the same problem with Borgeson steering joints. Even with loc-tite those little set screws seem to back off after a while. I've thought of using normal bolts and safety wiring them, but always worry the wire could somehow bind on the joint at a bad time, although its hard to imagine safety wire being strong enough to bind the steering. Just keep an eye on them and if you're steering feels sloppy check there first.
    19. #199
      SF Bay Area
      I'm using QuietCar. You might want to look into it. It's a liquid you can spray or brush/roll onto the surfaces. Goes on like thick paint. I have several friends who've done their cars with it already and swear by it. I'll use about 2 1/2 gal for my entire car. The best part is, it is MUCH lighter than DynaMat. A 5 gal bucket weighs about 50 pounds. And 5 gals would be more than enough for an entire car.
      chunger
      '68 Ranchero 500
    20. #200
      Jan 2010
      SLC. UT
      thanks for the info Chunger and John.
      i'll check that stuff out.
      Thanks very much for the info Zackalanche, that is good to know.
      once I figure out the hight I want to set it at, i'll have to mess with it.
      now is definately the time to make modifications to it, not after the car is finished.
