Results 1 to 10 of 10
Thread: when doing your own alignments
02-02-2010 #1
- Dec 2004
- 203
I started doing my own alignments last year on my '68 Camaro. I purchased camber gauge, fabbed up plates to measure toe, and borrow a friend's turntables (thanks Russell!).
One thing i noticed was that each time i make a change, it doesn't "register" until i take the car for a ride. Just dropping the car, bouncing on it, or even rolling it a little bit will not show a repeatable change. This, of course, gets tiresome as you iterate through your settings, especially if you have a car way off. My assumption is that stiction in the suspension is the main culprit?
My question for others that do their own alignments is: do you have the same issue? and have you come up with any clever ways to address it?
Also does anyone know if this is an issue when you have your car aligned professionally? Do they have a shaker table or something to settle the car after they make changes? Otherwise they aren't very accurate at all?
Thanks!
Paul
