    Results 1 to 7 of 7
      Indianapolis, IN
      Mike Norris Motorsports EFI Tuning In Your Area
      Hey All,
      I made posts in all of the regional areas pertaining to me doing tuning trips to different areas. Those threads include pretty much all the pricing and tuning info. Check them out and let me know if I can be of any service to y'all.
      Thanks.
      Mike Norris
      Mike Norris
      May 2007
      Macedonia, Ohio
      Hi Mike
      Glad to see tnhat you are moved and in business. Very good work at a reasonable price!
      I will look you up when in indy this year!
      Al
      Indianapolis, IN
      Sounds great Al, look forward to it for sure. You coming out for the Hot Rods and Restoration Show in March ??
      Talk to you soon.
      Mike Norris
      Mike Norris
      Feb 2008
      Sesser, Il
      Mike, do you tune TPI based vechicles? I'm still running the MAF GM computer but my engine is fairly modified. 383 with 230/236 113* Comp XFI hyd roller, AFR 190 heads and Accel SuperRam with 30# inj and adj press regulator.
      I'm having a start up chip burned by PCMforless but I'd like to get it dyno-tuned if I can find someone who still does TPI-based cars.
      Doug Gulley
      66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
      Indianapolis, IN
      Unfortunately it would be "no" on the TPI chips and tuning for the stock ECM. Now if you had a FAST or some other aftermarket engine management setup I could
      Mike Norris
      Mike Norris
      Burnaby, BC, Canada
      How about BS3 in Vancouver, BC, Canada area?
      My buddy has a new motor going together for his 4th gen.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Indianapolis, IN
      I can do that and a Canada trip would be good. I would have to get my passport and not sure if they will let me in :-) Heck, the US may not let me back once I leave.
      Just let me know and we can try and get something together.
      Mike Norris
      Mike Norris
