      what tranny set up should i go with
      I need some help with a tranny set up. Iam putting a new ls1 motor in my dads 69 camaro and iam not sure what tranny to use. Iam looking at the 4l65-e and the 4l60-e. He just wants a good daily driver.Does the ecm that comes with the ls1 crate motor control the transmission too or do you need the seperate tranny conroller also? And if so should i go with the Gm controller or go with an aftermarket controller instead.
      thanks for the help
      Jan 2003
      Arizona
      Either transmission will work fine. More than likely, you will find it easier to locate a '60. The LS1 ECU can be used to control the transmission. Programs like LS1-Edit will provide basic calibrating functions. So an aftermarket controller is not necessary for an LS1/4L60E application.
      If maximum control over your transmission sounds interesting, here is an abbreviated list of benefits from the Powertrain Control Solutions manual:
      BASIC TUNING
      Adjust shift points
      Adjust shift firmness
      Adjust TCC lockup
      Adjust Shift Speed
      ADVANCED TUNING
      Manumatic control (paddle shifting)
      Multiple shift modes (economy, performance, snow mode, tow mode, etc.)
      Datalogging
      Real Time Tuning
      Self Diagnostics
      These guys are very cool.
      (visit transmissioncontroller.com)
      http://www.transmissioncontroller.com
      ________________
      Steve Chryssos
      Clovis, CA (again)
      Hey Moto, I don't know the price difference, but check out Bowtie Overdrive's 200r4, it's what I'm running in my Chevelle, and it's been bullet proof. The company is really easy to work with and they can custom build to your specs.
      Dave H.
      where do i get ls1 edit from?
      Jan 2003
      Arizona
      ________________
      Steve Chryssos
