    Results 1 to 20 of 28
      Jan 2009
      I need a welder recommendation
      Hello all,
      I want to buy a mig welder. I want to use gas shielding, because I don't like chipping away at slag. Also, I do have access to a 220 volt outlet. My needs are primarily for thin gage mild steel (building frames/chassis tabs/sheetmetal work/etc), so I don't really need the biggest baddest welder.
      Do any of you have any recommendations for a decent gas mig welder?
      Midwest
      We've been using HTP welders for years with outstanding reliability and results. Check the MIG 140 for a robust 110 machine.
      http://www.usaweld.com/HTP-MIG-Welders-MIG-140-s/21.htm
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Hesperia, CA
      If you are looking for a small investment, the 220 Lincolns available at Home Depot are pretty cheap. Add your gas bottle and you should be able to do everything described.
      Dale Lee
      Dale's Speed
      www.dalesspeed.com
      IL
      I've used Miller for mig and as stated by Kevin the HTP but I use their Tig never used their mig. What ever you buy any of the brand names will do what ever you need. just don't buy an off brand because it's cheap. You will have a hard time getting parts if you need them down the road. Also if you have a local welding supply store try to buy from them because they will be able to help you if you have any problems and will have the consumables you will need. Plus you can get the gas from them. Hope this helps.
      Rick
      Jan 2009
      The ones I have seen at home depot don't come with bottles...what do I need to do to use gas with one of these units? Would a lincoln 180 HD weld pak work for me?
      Jan 2010
      just bought a 211, great unit! the autoset actually works well too!
      Nov 2009
      the dirty mitten
      You will need that tank itself, regualtor and proper hose for your machine. Mine has a barbed hose fitting, others have a push lock tube setup. You keep the regulator and hose. When you run the tank empty, just take it back to the store and exchange it for a full one. The initial gas setup will run you $150-$200. I pay $20 iirc to exchange tanks
      Steve
      Jan 2009
      Quote Originally Posted by bmms View Post
      A 211...what...is that a Miller, a Lincoln?
      Nov 2009
      Richfield, Wisconsin
      I would recommend going to a welding supply and see what they have to say, most carry the popular brands, and the prices are usually competitive...It's a one stop shop...welder, gas,wire...Whatever you need and a better selection...I bought my Lincoln "mig"from a local Praxair about 5 years ago...works great
      Steve R.
      68 Camaro
      Jan 2010
      Quote Originally Posted by mrn2obelvedere View Post
      it's a miller, w/DVS (dual voltage 110 or 240) in a compact unit
      Jan 2009
      I looked at the Miller website and it says the 211 can weld up to 3/8" in a single pass...this is really more welder than I need I think. The thickest stuff I can see myself welding onto might be welding up sway bar mounts to my rear end housing...nothing more thick than 1/8.
      Do you guys think the 180 might work for me? This is a 230V welder which welds up to 5/16" thickness in a single pass (still likely more than I'll be doing).
      Also, considering that I'd be doing mostly thin gage stuff (like up to .125" thickness), is there any advantage to using a smaller welder for me? I understand welding thick stuff is important sometimes, but when I want to weld something thin (say a quarter panel patch for instance) I want to have the flexibility to be able to do this without blowing holes right through the metal. In other words I don't want the lowest setting to be too much for small stuff. Would the larger welders have a problem with this?
      Think a bigger machine has more cooling so you get more duty cycle at lower power. If you're not welding big stuff, just use a smaller wire (to keep wire speed high and speed variation low)
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Rustburg, Virginia
      Also note that the larger machines, usually have more adjustability in them. So even though they will handle thicker materials and have larger duty cycles, they give you the ability to fine tune your settings. Whereas the smaller welders have preset selections that you have to use. These infinitely adjustable settings will come in handy vs the preset selections on the thinner gage materials.
      Jan 2010
      if you were going to spend the money on a miller I'd get the 140 or the 211 the 140 is quite a bit cheaper than the 211 and the 211 is just a little more then the 180. the 180 wouldn't be worth the savings compared to the 211 in my opinion. if you just want to do light body work and it's just for home use I'd buy the better of the two 110 lincolns from home depot that would suit your needs just fine, and if you have to weld say 1/4" you can do so with flux core or you can preheat your material with O/A torch, crank up the wire speed and weld thicker material with mig wire. But believe me you'll eventually see the many uses of a welder and you'll want a bigger unit. I am partial to miller if I went back in time I'd at least buy the miller 140 over the home depot welder. just FYI the lincoln migs that home depot sells are pretty much made exclusively cheaper for home depot
      Everett, WA
      Miller. I've used a lot of welders and Miller just makes a nice product at a "reasonable" price. The fine tuning of the larger models is super handy, even if you'll never weld 3/8".
      The few, the proud, the crazy... the LT1 owners.
      Jul 2008
      So Cal
      Rich
      71 Chevelle SS 454 clone M22W 4 sp
      Jan 2009
      Ok, so you guys have pretty much convinced me of the advantages of the Miller 211. It is a bit pricey but I am willing to bite the bullet and get it if it is the right tool for me. Now I am new to mig welding (I have some experience with mig, mostly with stick welding), so I need to know what else will I need.
      1) I assume I will need to buy a gas cylinder. What size is suitable?
      2) Also, what kind of gas will I need to use? CO2 or some mixture?
      3) The welder comes with a spool of solid wire, will this be suitable for getting started or will I need to buy something else?
      Nov 2009
      Good choice...You can't go wrong with Miller...
      You will have to buy your first tankof gas most likely, most welding shops will not rent to the general consumer. I prefer C-25 (75% argon-25% CO)...As far as size...That depends on usage...I use the "medium" tank...3ft. tall or so...Cost about $125 the first time and $30 for refill or exchange...
      Yes...solid wire (S6)...Depending on what size...I keep .025" and .030"...I Generally use .025 on body panels and .030 on floors and lighter fab....
      Welding gloves....Extra tips, gas nozzles..."Anti-Spatter" is also a good thing to have around....
      Welding helmet...Auto-Darkening...Is worth every penny in the car world....
      Practice...practice...practice...It's very easy to warp things and burn thru sheet metal...
      The setup chart on the welder is good guide to get you started...But it's a guide...You'll most likely develop your own preference for wire speed and heat....
      Steve R.
      68 Camaro
      Rustburg, Virginia
      Quote Originally Posted by rivs68 View Post
      Typically, you want to watch what's going on and then adjust or fine tune your arc. If you're getting a bunch of spatter, one of two things is out of whack: 1) too much wire feed speed(amps) for the amount of voltage, 2) too little voltage for the amount of wire feed speed.
      The thickness of your material will dictate which of those will need adjusting. Blowing holes through the material, means there's too much voltage or you're moving too slow and the material can't support that much heat. Heat input is an equation.(volts x amps x 60 divided by travel speed in/min) What I'm trying to say is that when you mess with one of the numbers in the equation it effects the other numbers proportionally.
      Spatter is the wire feeding too fast into the puddle causing large droplets of molten metal to fly out of the puddle. Really fine, light spatter is a sign that you are very close to an optimal setup. The arc should not sound like a war zone, but a gentle spraying, hissing sound. Now if you have a nice hissing sound, but the wire burns back up into the tip, you need to add more wirefeed speed into the mix to prevent the burn back and maintain a consistant ESO(electrical stick out measured from the contact tip to the work), over do the wirefeed speed and you're back to producing large quanities of spatter.
      Look for that balance....hope this helps.
      Jan 2009
      Ok this is a newb question, but I notice that the welders come with different wire sizes depending on the welder. Some come with 023 wire, some come with 030 wire. The question I have is with regards to the liner. If you are using a liner for 030 wire do you have to use 030 wire or can you use smaller wire with this liner? Same question but opposite direction, If I had an 023 liner would I have to change this to an 030 liner to use 030 wire?
